1 - 5 of 5 Posts
· Registered
Hi there.
I have searched high and low for seals for my oem brembo brake master cylinder for 2014 675R Daytona. I have removed the ABS and gone with new lines straight to calipers, pulled apart the M/C to clean but want to replace the seals. Asked my local triumph dealer to no help. Do not want to spend another 400-800NZD on the RCS 19. Has anybody found seals?
· Registered
Try sportbiketrackgear.com
· Registered
I'm not sure about the OEM 675R master, but I know on the RCS Brembo does not sell a full rebuild kit -you have to send the master to Brembo. They do sell a "rebuild kit" that replaces a few things, but it's far from a full rebuild.
· Registered
Hi
Been there done that. It took me ages to find. You're looking for brembo M4 caliper rebuild kits.
Motowheels has 2 options:
Caliper rebuild kit including pistons
Caliper seal kit only
I got the seals only since my pistons were like brand new.
Cheers
EDIT
My bad i thought you were looking for caliper kits. Sorry about that.
Regarding the master cylinder I needed one but couldn't find anything.
Ended up getting the 19RCS corsacorta as an upgrade / replacement.
OEM From triumph costs nearly as much and couldn't make sense of it.
1 - 5 of 5 Posts
