Brembo's new 19RCS Corsa Corta Radial Master Cylinder features three different brake modulation options: normal, sport, and race.
Normal Setting (N) - The "bite point" starts more gradually, ideal for city riding or braking in poor grip conditions.
Sport Setting (S) - The beginning of the bite point is shorter than in Normal, producing a more dynamic response ideal for sportier riding.
Race Setting (R) - The position of the cam mechanism shortens the initial stage of the bite point further, allowing you to reach the bite point of the brakes instantaneously. This setting is best used for track riding.
MSRP $318.00
Like the original 19RCS, the 19RCS Corsa Corta allows you to change brake lever ratios from 19x20 (for power) to 19x18 (for feel) with a simple turn of the screw.
The master cylinder housing is machined from forged aluminum with 5 axis CAM technology for top wear resistance. The floating piston, gaskets, and bleed & brake fluid delivery circuit couplings are the same as those used in MotoGP.
The Brembo 19RCS Corsa Corta incorporates a break-away lever for crash survivability.
Not yet listed on our website, you can order your Brembo 19RCS Corsa Corta Radial Master Cylinder by calling TJ at 866.931.6644 ext. 817. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
MSRP $318.00
