Seriously ****ing stop making threads.
Sorry about that. New to this.Seriously ****ing stop making threads.
I've also thought it might have to do with the wheel bearings also but I've check already and it all looks normal. Forks are not leaking at all. Like TwoWheelWonder mentioned it might just be break dust. There was a little on the rear also.That is weird. It looks like grease or oil. I'd be checking the fork seals and perhaps the front wheel bearings too.
I've had brake dust on my wheels before and it doesn't look like that. Normally it's an even film of dust that wipes off easily. Unless that's after you've tried to clean it with something and it's smudged?Like TwoWheelWonder mentioned it might just be break dust. There was a little on the rear also.
I haven't smudged it. That's how it looked after 2 hours total of commute and traffic. I'll take a picture tomorrow of the first hour of riding. It mostly looks like a cone shape with a dark spot at the tip of the cone. Then fading away as it spreads into a cone shape.I've had brake dust on my wheels before and it doesn't look like that. Normally it's an even film of dust that wipes off easily. Unless that's after you've tried to clean it with something and it's smudged?
That's a good idea, while I'm at it should I do the tires too. Or would be better to douse them in armor all?No need for multiple threads. If it does end up being brake dust. Throw some wax on your rims and it will be very easy to clean off in the future. Re apply the wax every season for best results.
Thanks! Rim wax is a good idea. Yesterday I grabbed a dry microfiber and wiped the dust off. Works well for a quick clean. Then I'll detail it and use rim wax on the weekend.get a microfiber towel and lightly spray with goo-gone, wipe the rims then clean with soap and water. This will remove any grease stains that are hard to remove. Then apply rim wax so that dirt and grime doesn't stick to the rim. See if that works.
Rim wax is a great product, you could wipe your fingers with a white glove on my rims and wouldn't find any dirt, grease or grimeThanks! Rim wax is a good idea. Yesterday I grabbed a dry microfiber and wiped the dust off. Works well for a quick clean. Then I'll detail it and use rim wax on the weekend.
