What an amazing bike this month! I can't get enough of the last picture. A Street Triple destroying a bike with double the CC's!!!!!!!!!!!!!!!!!!!! :thumbup:
Congratulations NAK3D on a well deserved win!
This is my 2007 Street Triple. I have owned it since new, and over the years it has seen some continued changes year on year.
I am currently having a little fun with it on the drag strip, so don't ride it much on the road lately. It is usually ridden very regularly ….. hope you like it.
226.5rwhp with 328ft lb of torque
Armstrong rear brake rotor.
Powder-coated brake calipers.
Removed chain guard & sprocket cover.
Removed OEM rear fender, replaced with R&G. will make a custom unit this year.
Triumph gel seat.
Triumph seat cowl.
Rizoma rearsets.
Powder-coated gear selector rod and brackets.
Rizoma fuel cap.
Rizoma oil cap.
Poweder-coated headlight cups.
Removed mirrors.
Pazzo 'shorty' levers.
Modified Garrett GT20 Turbo (ceramic / powder-coated).
VDO Scavenge pump.
K&N pod filter.
Custom Turbosmart Ultra-Gate 38 with screamer pipe.
Turbosmart Single stage boost controller with 2 boost settings (8psi / 11psi), toggle switch on instrument cluster.
2012 Street Triple R rhs frame insert.
Walbro fuel pump.
Turbosmart fuel pressure regulator FPR800 with Gauge.
Custom exhaust.
Triumph fly screen.
Rear hugger removed.
Currently has Shinko 'Hook Up tyre (Drag only).
Daytona rear shock (not pictured).
Lust Racing lowering link - 35mm (not pictured).
T-Rex adjustable lowering link (lowered another 60mm).
Forks pushed through clamps 36mm to lower the front (not pictured)
Brocks lowering straps (drag only).
Custom intake plenum.
SAI mod.
1 off custom Turbosmart BOV.
Watsen Design front indicators (low rise of Speed Triple).
Hyper Pro Steering Damper
Integrated rear light.
Rear pegs removed.
Street Triple R radiator cowls.
Radiator guard.
Comp Mods piggy back ECU.
CP Carillo low compression custom forged pistons.
Black 525 chain, Black rear sprocket (standard gearing), +1 on front sprocket.
Custom Intercooler with shroud.
