Had the rep in today trying to get us to sell his batteries. They look the part and sound idea. Only problem is I'm no expert but I know the Tona is funny when it comes to batteries so can someone in the know cast their eye over the specs below and say if we need the 6 or 8 cell? I know the 4 cell one will do a race bike no probs, not sure about a road bike with headlights on.
Product Specifications
4 Cell Superlight Race Battery
Specifications:
Voltage
13.2V
Nominal Capacity
2.6Ah
Weight
390 g / .86 lbs
Dimensions
106mm x 27mm x 72mm
Suggested Use
4-Stroke up to 600cc
Recommended Operating Conditions:
Max Continuous Discharge
50A
Pulse Discharge (10 sec)
150A
Operating Temperature
-4°F to +140°F / -20°C to +60°C
Standard Charge
5A to 14.4V
Fast Charge
10A to 14.4V
Charge and Cutoff Voltage
14.4V to 8V
8 Cell Superlight Race Battery
Specifications:
Voltage
13.2V
Nominal Capacity
5.2Ah
Weight
730 g / 1.61 lbs
Dimensions
106mm x 54mm x 72mm
Suggested Use
4-Stroke up to 1000cc, 2-Stroke up to 300cc
100A
300A
Standard Charge
7A to 14.4V
Fast Charge
20A to 14.4V
14.4V to 8V
12 Cell Superlight Race Battery
Specifications:
Voltage
13.2V
Nominal Capacity
7.8Ah
Weight
1060 g / 2.34 lbs
Dimensions
106mm x 81mm x 72mm
Suggested Use
4-Stroke up to 1500cc / 2-Stroke up to 500cc
150A
450A
Standard Charge
10A to 14.4V
Fast Charge
30A to 14.4V
14.4V to 8V
Specifications:
Voltage
13.2V
Nominal Capacity
2.6Ah
Weight
390 g / .86 lbs
Dimensions
106mm x 27mm x 72mm
Suggested Use
50A
150A
Standard Charge
5A to 14.4V
Fast Charge
10A to 14.4V
14.4V to 8V
Specifications:
Voltage
13.2V
Nominal Capacity
5.2Ah
Weight
730 g / 1.61 lbs
Dimensions
106mm x 54mm x 72mm
Suggested Use
100A
300A
Standard Charge
7A to 14.4V
Fast Charge
20A to 14.4V
14.4V to 8V
Specifications:
Voltage
13.2V
Nominal Capacity
7.8Ah
Weight
1060 g / 2.34 lbs
Dimensions
106mm x 81mm x 72mm
Suggested Use
150A
450A
Standard Charge
10A to 14.4V
Fast Charge
30A to 14.4V
14.4V to 8V
