1 - 9 of 9 Posts
· Premium Member
Arguably one of the most cost-effective handling upgrades you can make to your machine, suspension aside - is a set of triple clamps … and the best triple clamps you can buy come from Attack Performance.
Designed and manufactured in-house at Attack Performance's headquarters in Huntington Beach, California, GP Triple Clamps can be found on some of the fastest motorcycles racing the USA, today.
Each set is built using top-quality aluminum that is CNC-machined in a way to provide lightness, strength and targeted flexibility so as to substantially increase front end feel without making the bike nervous or otherwise ill-handling. It's all held together using top-shelf hardware which makes for a sound installation, too. And for the consummate tuner, additional inserts are available which allow you to adjust offset with ease.
Available for a wide range of bikes, you know the routine, give TJ a call on 866.931.6644 to get this, or any other Attack Performance component sent straight to your door. Of course, [email protected] or a PM works, too!
· Premium Member
Discussion Starter · #9 ·
The front end on the Daytona from the factory is quite aggressive. These clamps allow you to adjust the offset on the triples, which can make the bike more stable without affecting the quickness of steering.
1 - 9 of 9 Posts
