I have Tuneboy/Tune edit and they work pretty well
I have a reasonably modern laptop and have had no problems with installing or running the program.
I have had no connection issues between laptop and ECU -
I have had the bike on a Dyno and used Tune edit to modify the fuel and ignition maps (well the technician did it actually I just watched
The diagnostics correctly identified I had not plugged in the secondary air induction system after some engine work .
I have not (until now
) heard of tuneECU or I probably would have checked it out.
Whether it is worth it or not ? I think so even though it's not cheap.
Bear in mind you can turn your ECU into a brick if you download crap to it
It's a bit like updating the BIOS on a PC and getting it wrong - and I have to confess to doing that !! ( I'm a systems guy
It is also cool if you lap times are crap you can connect up in the pit and frown knowingly at the screen and pretend the bike was not running right :lousyputer_smilie:
