Alpinestars Hyper Drystar Motorcycle Jacket
1757 Views 1 Reply 1 Participant Last post by  RidersDiscount
One jacket for all conditions; the Hyper Drystar is just the right combination of breathable comfort, and waterproof protection.
CE-approved armor is fitted in the shoulders and elbows and compartments for a back protector and chest inserts are included if you really want upgraded protection. It's all housed in a heavy-duty, yet flexible poly fabric, dobby-reinforced covered in an Alpinestars Drystra taped-seam chassis.
Particularly unique for this jacket is the way it can be adjusted to fit your body's exact shape. Tabs are found on either side of the torso, along with hook-and-loop drawstrings at the waist. In the arms, too, is another set of hook-and-loop tabs that draw the jacket as close, or far - as you want from your body. The result is a keenly fit jacket that'll keep you dry when the skies open up.
Ventilation is looked after via a series of zippered intakes on the front and back of the jacket. These, of course, can be drawn closed when it's cold, or rainy, but are more than capable of moving lots of air when needed. And we should mention that, inside the jacket, you'll find a removable liner, too, for the really cold weather.
This jacket isn't a one trick pony - rain or shine, hot or cold, it'll get the job done for a lot of riders!
Get this jacket by giving TJ a call on 866.931.6644 ext 817. Or, just send a note to [email protected] with ALPINESTARS HYPER DRYSTAR JACKET the subject line and we'll get back to you right away.
1 - 2 of 2 Posts
The Alpinestars Hyper Drystar jacket offers a tab on either side of the torso to tailor the fit of the jacket to your body shape. Call 866-931-6644 to order!
1 - 2 of 2 Posts
