1 - 5 of 5 Posts
ive gots a question for you all, i was putting my bike back together, i had it all stripped b/c i wrote it off in october, well some off my parts came in, I had to change the front bird cage and air ducting. I had it stripped since nov, the only problem i have is, under the cluster there is a sensor, not the vacuum diaphram on the air ducting, looks like a air temp sensor, i have it mounted and all, but it looks like there should be a vacuum line that goes to it.
I cant find any other hoses that should route to it, ive got the one hooked up to the vacuum modular, anyone can help me pls,
I am guessing that is your baro sensor. It should not have a vacuum line, even though it looks like it should.
1 - 5 of 5 Posts
