1 - 6 of 6 Posts
Bought a instrument cluster to replace damaged one. Also have a new multilock 16p connector as mine was ripped off. I do have a wiring diagram but nowhere can I find the cluster pinouts i.e. what is the position of pin 1 on the cluster?
Could someone please tell me if its numbered from right to left and if row 1 is @ top. A pic of the connector would even be better.
Thanks.
Thx LCX.
I also previously found the site that you refer to but it confuses me as the pinouts for the ECU counts from right to left.
Thx LCX.
Did you ever find the solution? I have the same problem, all my wires are ripped out of the cluster plug and do not know what wire goes on what pin. I can’t seem to find anything much on this topic
Dash connector 12' st3R no abs no immobilizer
Standing in front of the bike (side of connector that has no release clip)
Left to right
Black with yellow stripe
White with red stripe
Blank
Blank
Blue with white stripe
Green with white stripe
Green with red stripe
Blank
While sitting on the bike (side with removal clip)
Left to right
Black with silver rectangle
Purple with silver rectangle
Green with silver rectangle
Red with silver rectangle
Solid blue
Solid black
Solid black
The last two solid black wires could have had the silver rectangle and it was just rubbed off. I'm not sure if the two solid blacks side by side are interchangeable or not.
259838
259839
1 - 6 of 6 Posts
