1 - 4 of 4 Posts
Hello all,
I have searched on here for a while and can't find my exact situation and everything that I have tried has come up empty.
First off, the battery is at proper levels while the bike is off, with accessories on, and when it's running. I just installed a brand new battery today. So that doesn't seem to be a problem.
Whenever I try to start the bike, the dash comes on, I hear typical fuel injector noise and the EXUP valve doing its thing like normal. However when I pull the clutch in and try to start the bike it does nothing. The lights don't dim, no noise, or anything.
Has anyone else had this problem? If so how did you go about resolving it?
PS: I did get an engine light a couple weeks ago and after plugging the bike up it was a problem with the EXUP valve. Would a possible delete help, or is that just an effect of an aftermarket exhaust?
Thanks!
Discussion Starter · #4 ·
SOLVED!
100% correct, went out today, took off the clutch lever and gave the switch a good cleaning and lubricating and now it fires right up! Thanks a ton!
1 - 4 of 4 Posts
