1 - 20 of 42 Posts
· Registered
2006 Daytona 675
Hey 👋
I have a 2006 Daytona 675 Triple, when I press the ignition it makes no noise, no lights turn on, nothing though the dash lights up as it should etc.
Key points:
  • new battery
  • new gas
  • solenoid fuse good (bike had started up a month prior)
I'm stuck 🤷 any help to get her up and running is appreciated!
Thank you
b 🤘
· Registered
2006 Daytona 675
Discussion Starter · #8 ·
Did it stop working out of the blue? Or mid ride? Was it when you were making a U turn/right turn/left turn? If Yes I would check the ignition key switch cables. Had this issue recently
It had been sitting for a bit, started it up in June with a boost then sat until a week ago when I tried to turn it over and it doesn't do anything. Ok I will check those
1 - 20 of 42 Posts
