This thread is meant to aid in the track setup of a new (to me) bike and to document the build. This is gonna be a good time for sure, but hard on the pockets!!
I got a killer deal on an 06, it wasn't running and turned out to be a simple electrical problem. Got it for $1700, 20k miles but is in pretty good condition. I used to race a Ducati 996 but took a 5 year break. Just took the 675 to the track for the first time and oh baby it's ON. I want to keep the budget as low as possible. I have questions about geometry, suspension options, head mods/compression changes, etc. Thanks in advance for your help!
So far I have changed the battery, air filter, spark plugs, oil, fork seals, brake pads, and some other small stuff. I have a set of billet rearsets (only $123 so hoping they are solid) and Yoyodyne slipper on it's way. I wanted to find a used slipper but haven't seen any so I dropped the $830 on it, OUCH. But worth it in the end. The local track is pretty tight with a 35 mph hairpin and mostly right hand turns. The surface is on the rough side. I started in intermediate last weekend and after 3 sessions they bumped me up to expert as I learned the track. So my pace is pretty decent but I'm not fast again yet. I was never really that fast before anyway but here's a second chance to start winning races!
1. SUSPENSION: For a bit of a bumpy track, the stock suspension worked quite well (I'm 200 lbs geared). Fork settings C=13, R=2, P=6th line flush; Shock settings C=16, R=2, P=4 threads showing. As I pick up pace I might need to address the valving soon, my question is: are there resources for track shim stacks with stock pistons? Are results better with RT gold valves (they give you shim stack recommendations but they are not cheap)? Do you guys upgrade to newer model year internals, and do the newer shocks have better components (not Ohlins) and do they fit the 06? The Ohlins look to be about 500 bucks so not cheap. The 06 shock came with a progressive spring, right, at 12.6 kg/mm? Will valving accommodate a linear spring and does this seem to be the direction to go? Spring rate recommendations? 10.7 kg/mm is an option?
2. GEOMETRY: I set the forks to show about 1 mm of fork tube above the top triple (the gold outer tube not including the cap). I could see dropping the front a little but I also just rotated the clip ons out so the front should be more weighted now. I am 6'2 and have not felt like I am fitting the bike that well, hopefully with the clip on move and moving the pegs back 5 mm or so it will help. The tank just seems very narrow and you slide very far forward under hard braking. Can you raise/lower the rear or is that not adjustable? The swingarm does look adjustable, what settings do you run?
2. GEARING: Stock is 16/47 but have heard 15/49 is the hot setup for tighter tracks. I have a 15t coming so might try that with the 47, or is that not enough? Thoughts? Looking forward to harder drive out of the corners.
3. FAIRINGS: Been looking for fairings on ebay and such, would rather not go new but the used ones available are still kind of expensive or need repairs. Any cheap options out there? Was also considering bondo or similar to close up the headlight holes and sheet plastic to close off passanger seat hole, not sure how janky that would look. Also the tail has a gap for the tail light so not sure how to deal with that.
4. Increasing the compression by decking the head seems like a go to for 675 tuning. The 3 closest tracks are all above 4,300 ft with the most often one I'll go to being 5,300 ft. so I have room before detonation happens. How much are you guys taking off, I have read 0.004-0.006" or so? Head gasket thickness? Would it be necessary to retune when you deck the head or could you run stock tune for a while without it being dangerous? I have a dyno tuner a few hours away, what tuning hardware are you guys having luck with? PowerCommander, Bazazz is good, but there are cheaper option like tuneECU but not sure its limitations for custom tuning.
Thanks for any help!!
