1 - 20 of 120 Posts
· Registered
When it comes to the 2006-2012 steering stop Triumph seems to have overlooked their design slightly. Many of us have suffered from a broken steering stop after crashing, ultimately leading to a salvaged title. This stop may be used as a protector for the stock design or as a full replacement. To prevent the stock steering stop from breaking, this design stops the triple tree prior to contacting the cast frame but only limits steering by ~1 degree. All hardware is stainless and the stop has been anodized to keep it looking good for years to come.
The stop is offered with both aluminum and Delrin frame plates. It is recommended that the aluminum be used for stock applications and the Delrin or aluminum be used for track applications; the Delrin design allows 2mm of plastic deformation before the bolted hardware goes into pure shear, reducing the impulse loading at contact.
At this time the stop does not support the stock steering damper, but a separate piece is being designed to replace the stock mount structure.
PM Munch or myself for pricing details.
· Registered
So this bolts to where the stock steering damper mounts on the Daytona? If that is the case then unfortunately it will not work on my Street Triple. They don't have the damper mounting points.
The stop bolts to where the stock damper bracket mounts on a Daytona 675. The street triple never had a damper bracket or mount on the triples but I believe that they left the threaded holes open on the frame, which this mounts to. A quick check will confirm or deny this.
· Registered
Would be interested if it could be modified to accommodate a damper (mine is aftermarket) in the stock location.
If that's possible, PM price and shipping costs to Australia, please.
I had an SES limiter on a previous 675 track bike but it greatly reduced the turning ability (and therefore increased turning circle). It wasn't an issue on track but made it harder to maneuver in the garage, and also prevented the use of the ignition lock.
· Registered
I just bolted mine up to my Daytona last night and the fitment was perfect. Cant wait for my next track day. When tech asks me to "move from lock-to-lock" I wont have to fake it next time!!!
Now I'm waiting for some one else to post up a crash test.
· Registered
No the Street Triple Triple triples are completely different in geometry and design and do not have damper mounting points.
Unless I'm mistaken, this bolts to the frame and not the triple clamps. On a Daytona you'd have to remove the black bracket for the damper. On a ST there is no damper or bracket so just bolt it up. The holes in the frame are still there.
· Premium Member
Well crap. Teaches me not to go look. Thank you.
I knew it bolted to the frame but I was sure the Street Triple frame didn't have the mounting points for the damper. I just went and looked an what do you know. One unused hole and one with a cable guide mounted to it.
· Registered
Discussion Starter · #12 ·
Just a heads up to anyone who purchased these that the frame protector flat heads require an english allen key, rather than metric. I may include the allen key in future purchases. The reason is due to metric vs. english thread pitches.
· Premium Member
Why is the mounting bolt metric and the spacer bolt English or is te English 5mm the same as the metric 5mm? That may explain another weirdness. The the bolt going into the frame was kind of tight even before it go to the encapsulated thread locker. So I compared it to the bolt I took out and the pitch was a hair different. The OEM one I took out was a perfect metric 1.00 pitch but the one in the kit was not.
· Registered
Discussion Starter · #14 ·
The frame bolts are a metric 6 x 1.00 and should comply to DIN 912 and have a class 6g fit, they are also made of 316 SS so by all nature they should be significantly better than what is included from the factory. I am unsure why the bolts you are measuring are not compliant with your thread gauge.
The bolts used for mounting the frame plates onto the contact plate are 10-24 english. The reason that these are english rather than metric has to due with the differences in standard thread pitches. A course thread metric is .8mm which is roughly equivalent to a fine thread english bolt (10-32). Since the shear strength of delrin and aluminum is low in comparison to the 316 SS flat head I wanted to use a courser thread to provide greater resistance to thread shear at assembly. For a given length courser thread pitches will have a higher thread shear load due to the increased area.
I will include the appropriately sized allen key with delrin purchases to remove the seperable plates.
· Registered
oooooo didn't know this existed. I'm shopping for a new frame, and this opens up new possibilities for ones with broken steering stops! May be purchasing from you soon.
edit: just noticed you're located in MA! do you have a stock of these, if I were to need one on short-ish notice?
1 - 20 of 120 Posts
