Maintenance & Repair FAQ's, HOW TO's, & other info - Triumph675.Net Forums
post #1 of 41 Old 03-06-07, 18:23 Thread Starter
AdamB
Retired Administrator
AdamB's Avatar
Maintenance How To Guides
--How to: Replace the Air Filter
https://www.triumph675.net/forum/showthread.php?t=8454
--How to: Install a New Chain and Sprocket
https://www.triumph675.net/forum/showthread.php?t=36107
--How to: Adjust The Chain
https://www.triumph675.net/forum/showthread.php?t=926
--How to: Change The Coolant
https://www.triumph675.net/forum/showthread.php?t=8035
--How to: Free a Seized EXUP Valve
https://www.triumph675.net/forum/showthread.php?t=21392
--How to: Remove The Fairings
https://www.triumph675.net/forum/showthread.php?t=894
--How to: Remove The Gas Tank
https://www.triumph675.net/forum/showthread.php?t=8373
--How to: Remove The Head Gasket
https://www.triumph675.net/forum/showthread.php?t=26759
--How to: Change The Oil
https://www.triumph675.net/forum/showthread.php?t=10896
--How to: Adjust The Throttle
https://www.triumph675.net/forum/showthread.php?t=881
--How to: Balance The Throttle Bodies Using a Tuneboy
https://www.triumph675.net/forum/showthread.php?p=429931
--How to: Measure The Valve Clearance
https://www.triumph675.net/forum/showthread.php?t=27207
***A PDF file containing most of the maintenance How to guides can be found by clicking on the link below***
https://www.triumph675.net/forum/showpost.php?p=385104&postcount=25
Modifications:
You're in the wrong sub-forum but being the helpful mod that we all are... here's a link to all the mod stuff:
https://www.triumph675.net/forum/forumdisplay.php?f=13
Critical torque values. Much appreciatd Nikola 330!!
NOTE: These are out of date values and may have changed. Need confirmation.
Spark plug.............12Nm
Oil filter..................10Nm
Front Brake Caliper Bolts..............35Nm
Brake Hose Banjo Bolts.................25Nm
Camshaft Cover Bolts....................12Nm
Fronr Wheel Spindle Clamp..............20Nm
Sump Plug......................................25Nm
Front Wheel Spindle Nut...................65Nm
Steering Head Bearing Nut...............90Nm
Rear Wheel Spindle Nut...................110Nm
Rear Brake Caliper Bolts.................(M8)22Nm
(M12)27NM
Rear Brake Master Cylinder Bolts.....18Nm
Brake Pad Retaining Pins....................17Nm
Fuel Tank Mounting Bolts....................9Nm
Last edited by Budo; 07-19-10 at 04:16. Reason: added updated info with help from Cloud
AdamB is offline
post #2 of 41 Old 03-06-07, 21:12
toxidomask
dude!! you are the man!! thanks for cleaning it up a bit.
toxidomask is offline
post #3 of 41 Old 03-07-07, 11:52
valoflyby
valoflyby's Avatar
Yes, agreed, this is *much* better. Good way to go.
Jeff
Current Stable:
Two Wheelers: 06 Triumph 675, 04 BMW R1150RT, 91 Suzuki VX800, 88 Honda HawkGT
Four Wheelers:05 Jeep Liberty CRD Limited, 02 Hyundai Accent ("The Dingy")
valoflyby is offline
post #4 of 41 Old 03-07-07, 13:09
ShaneXman
ShaneXman's Avatar
Send a message via AIM to ShaneXman Send a message via Skype™ to ShaneXman
Nice job Adam...it's lookin' good! 8)
(`'.-Shane-.')
"Happiness is not around the corner; it's IN the corner."
http://www.mothers.com/
ShaneXman is offline
post #5 of 41 Old 05-09-07, 11:19
Budo
#10, the complete set of torque values is out of date i think. The link to the pictures @ photobucket is no longer there, so the pictures are no longer on the thread either. Just thought i'd point it out...
TACTAA
The bad thing about riding a motorcycle is you cant hear the phone ring.
The good thing about riding a motorcycle is you cant hear the phone ring.
- Scott P.
Budo is offline
post #6 of 41 Old 05-11-07, 09:38 Thread Starter
AdamB
AdamB's Avatar
Thanks for tipping me off on that Budo! That stinks. It was really nice to have the torque info handy :(
chimkychink-- you bastards
chimkychink --we gave you america...you gave us a ****ing squirrel...that killed all the other ones
AdamB is offline
post #7 of 41 Old 05-11-07, 09:57
Marko
Marko's Avatar
I think this is way more accessible, particularly for new members.
M
Marko is offline
post #8 of 41 Old 05-12-07, 19:28
valoflyby
valoflyby's Avatar
Re: Maintenance & Repair FAQ's, how to's, & other in
Originally Posted by AdamB
8. HOW TO: Change Your Coolant Guide
https://www.triumph675.net/phpBB2/viewtopic.php?t=9016
Bennie Blanco was kind enough to contribute this one. (To give credit where it is due). :)
Jeff
Current Stable:
post #9 of 41 Old 05-29-07, 16:00 Thread Starter
AdamB
AdamB's Avatar
^^^^^ Thank you! :2tu
AdamB is offline
post #10 of 41 Old 08-04-07, 14:07
warpedreality
warpedreality's Avatar
If I may...
Originally Posted by [url=https://www.triumph675.net/phpBB2/viewtopic.php?t=3861
R6O7B5[/url]]I was looking for the paint code for the Scorched Yellow and thought I'd post my finding for owner reference.
Color / Paint Code / Dealer PN for touch up
Scrorced Yellow / (L4819) 1000792 / T3120300-FG
Tornado Red / (L2804) / T3120300-CM
Graphite / (L3725) / T3120300-LC
Hope this comes in handy! :D
Thanks R!!
tags: paint code paint codes
warpedreality is offline
