HOW TO: Better way to disable headlights... - Triumph675.Net Forums
post #1 of 48 Old 08-17-06, 22:05 Thread Starter
valoflyby
valoflyby's Avatar
Many thanks to Will for tipping me off to the possibility of the "obviously easy".
Many moons ago I had incorrectly posted a "how to" disable the headlights with the explicit instructions to remove the headlight fuse. As many of you know (by now)... this also disables the starter relay. Not good.
There *is* an easier way than removing the four phillips screws for the lowbeam.
Pull the left-hand dash panel inlay. This is the one that you'd normally pull to get to the fusebox. The connector that we're looking for is currenty under the fusebox and relays.
Trace the wire circled in blue. If you "pop" the fusebox off the fairing nubs, and pull the flapper vacuum line out of the way, you'll find a connector underneath.
Pull it up and above the fusebox:
Disconnect!
Replace panel... and go!
BTW... the horn is still hot... I tried removing the horn fuse, and it seems tha the dash panel is tied into this 10A fuse. If you're worried about inadvertantly "beeping" those that you're overtaking.... just pull one of the leads off the horn (next to the steering dampner).
Enjoy! (Make sure you reconnect everything before street use..)
Jeff
Current Stable:
Two Wheelers: 06 Triumph 675, 04 BMW R1150RT, 91 Suzuki VX800, 88 Honda HawkGT
Four Wheelers:05 Jeep Liberty CRD Limited, 02 Hyundai Accent ("The Dingy")
valoflyby is offline
The Following User Says Thank You to valoflyby For This Useful Post:
one4ale (01-12-14)
post #2 of 48 Old 08-17-06, 22:07
Grashopr
I think I know the answer to this question, but does this also disconnect the 'running lamps' on the sides of the headlights?
Grashopr is offline
post #3 of 48 Old 08-17-06, 22:10 Thread Starter
valoflyby
valoflyby's Avatar
Yessir! Everything that previously *could* be illuminated ... is now disabled.
Oh, happy days... oh happy days... never will I worry about dropping one of those damned philips screws down inside the fairing again. I'm willing to bet that I can "track prep" the bike in :30 now. ;)
Jeff
Current Stable:
post #4 of 48 Old 08-18-06, 05:19
Scarlet
Brilliant - thankyou for that valoflyby
Scarlet is offline
post #5 of 48 Old 08-18-06, 05:25
Abzz
Abzz's Avatar
:lol: I "helped" Nitro Norrie (Martin) prep his bike at Brands on Wednesday and managed to drop two of the little buggers in to the fairing never to be seen again (but i managed to do my own ones OK :oops: )
Thanks for the tip mate!
The older I get the faster I was!
1981____________________2007
Abzz is offline
post #6 of 48 Old 08-18-06, 17:15
carlitobaby
Wicked - no kore lost screws as Paul will testify to at Brands on Wednesday - sorry if you can't find that screw I lost in the fairing :oops: :oops: :oops: :oops: :oops: :oops:
A little less fiddly and no need to have acast of thousands trying to find some really small screws.
Carl
RC Racing 12 HMRC Junior Tag 600 http://rc-racing12.webs.com/
We do it different at www.matmob.com
carlitobaby is offline
post #7 of 48 Old 08-19-06, 00:40
Will
Will's Avatar
Those screws disappear really quickly when you drop them. I lost two of four after the last trackday. :roll: Triumph want $9 each for them, but you can get stainless replacements at a hardware store for about a quarter. Maybe $0.50, I don't remember, but certainly not $9.
If it runs right, I didn't tune it.
Will is offline
post #8 of 48 Old 08-19-06, 11:41
motojc
Thank you so much! I went to the first track day last wknd, after reading the fuse also does the starter relay, so with my philips screw driver, I only found out it was ****ing impossible to get to the inside screws of the head light casing.
next wknd I'll be happier.
motojc is offline
post #9 of 48 Old 08-19-06, 13:10
kneepuck
kneepuck's Avatar
Thanks!! I just read this after yesterday's trackday, but have two more coming up before the end of the month. Great tip!!
If you don't smile every time you climb aboard your 675, fire it up, and chuck it into a corner, don’t bother checking your pulse. You’re already dead.
kneepuck is offline
post #10 of 48 Old 08-19-06, 14:07
Sammy901
Sammy901's Avatar
I take it a step further--I also put painters tape over the high/low beam selector swtich (in the low beam position) which will keep the switch locked in the low beam position. This will keep you from accidently swtiching on the other headlight and toasting the tape to the lense.
BTW-I still think you need to pull a fuse to disable the running lights. It's the 5amp (not sure) orange/yellow one I think.
Eric Cartman : "my heart says yes, but my vah jay jay says no"
Sammy901 is offline
