Dead spot with ASV Shorty Brake Lever on 675R? - Triumph675.Net Forums
post #1 of 6 Old 07-31-20, 01:03 Thread Starter
Derrick Wang
Hi all,
Got a 2012 675R and just installed an ASV shorty brake lever. I noticed immediately that there seems to be a dead spot for the first inch where there's little to no brake power, and then after all the brake power comes in. This wasn't the case with the OEM lever. Does anyone have this experience with a shorty brake lever? If so, any way to fix this? Thanks
Derrick Wang is offline
post #2 of 6 Old 08-01-20, 08:26
Chirp
The one time I've had an issue with an accessory brake lever it was down to the small pushrod between the lever and the cylinder. I took the one from the stock lever and that fixed it. YMMV
'61 Clubman's Gold Star, '13 Duke 690, '13 Daytona 675R (track bike), '18 Street Triple RS, '20 R1250R
Chirp is offline
post #3 of 6 Old 08-01-20, 11:44 Thread Starter
Derrick Wang
Thanks for the response. When you say small pushrod, do you mean the black plunger pin that sticks out of the OEM lever? AVS supplied their own that I've installed. If so, is the OEM plunger removed off the lever by turning the nut?
ID:	253277   Click image for larger version
post #4 of 6 Old 08-02-20, 07:56
Chirp
Just so. As to installation I have no idea. I had a similar problem on my Duke which has a non-radial MC and that's how I fixed that.
Chirp is offline
post #5 of 6 Old 08-02-20, 11:20 Thread Starter
Derrick Wang
Gotcha. Was it also an ASV lever? If so, I'm surprised by this since they're a premium name
post #6 of 6 Old 08-05-20, 07:09
Chirp
No, ebay from China.
Chirp is offline
Tags
asv , brake
