Name of this connector - Triumph675.Net Forums
post #1 of 4 Old 11-18-19, 19:31 Thread Starter
Plasmablaster
Plasmablaster's Avatar
My buddy's 675 is playing up - it refuses to start and the culprit is this connector in the pic. It's the connector of the headlights and I don't know what else (it's located under the tank, near the SAI). If we move it around it might start but it's been bugging him for a week with no good solution at hand so the connector needs to be changed. Does anyone know the name/type of the connector?
Name:	Lights Connector.jpg
Plasmablaster is offline
post #2 of 4 Old 11-20-19, 07:30
Gosling 1
Looks to be a Sumitomo DL sealed 8-pin connector.
You have to scroll down the page of this link a bit to see it.
http://www.easternbeaver.com/Main/El...SMDL/smdl.html
Gosling 1 is offline
The Following User Says Thank You to Gosling 1 For This Useful Post:
Plasmablaster (11-20-19)
post #3 of 4 Old 11-20-19, 17:10
keeena
Gosling is right; its a Sumitomo DL. You can also find them at CycleTerminal (that's where i usually get my OEM plugs): http://www.cycleterminal.com/dl-090-series.html. Joe is a good guy - you can shoot him pictures if you're not sure what type.
Related: the 2 fuel pump connectors (pump and level) are Sumitomo HX .090 and can be found here: http://www.cycleterminal.com/hx-090.html. The 2 plugs have slightly different keyed fittings (the little tabs/slots) so pay close attention to which one you need. I did a set of these last year for a buddy's trumpet.
Get a decent crimp tool if you don't have one already. This is one of the ones I have that works for this size Sumitomo; has interchangeable anvils for different sizes: https://www.amazon.com/Engineer-PAD-.../dp/B00IWD9XKU
keeena is offline
The Following User Says Thank You to keeena For This Useful Post:
post #4 of 4 Old 11-20-19, 17:32 Thread Starter
Plasmablaster
Thank you so much guys. Really appreciated. Never occurred to me to look on those websites although I was aware of them doh.
I already have a crimper and I've gotten quite deft at using it. If it doesn't work well with those terminals I'll look for another one.
