06 Daytona cams in 15 Street Triple - valve clearances? - Triumph675.Net Forums
post #1 of 3 Old 08-10-20, 07:34 Thread Starter
Michael Kelly
Hello everyone! I am planning to install some 06 Daytona cams in my 15 ST, and have a question. In my Haynes Manual, the valve clearance on the exhaust cam for the earlier Daytona is 0.275mm to 0.325mm, but for my ST it's listed as 0.325 to 0.375mm. When I fit the cams, should I use the clearances for the Daytona, or for my bike?
Thank you!
Michael Kelly is offline
post #2 of 3 Old 08-10-20, 11:46
samwise_i
The cam journal size is different between gen1 and future gen engines.
06 cam journal size 23.900mm
09+ cam journal size 23.950mm with a minimum size of 23.940mm
It might work, but it violates the service manual's specs.
samwise_i is offline
post #3 of 3 Old 08-19-20, 23:18 Thread Starter
Michael Kelly
Hi there, thanks for your response. I didn't actually see this in time, and I have now actually installed these in my bike. They were indeed 0.04MM smaller in journal size than the cams I removed.
The bike runs fine, aside from fueling issues. I hope the journal size difference will be OK.
Thanks again!
