Weird Noises! - Triumph675.Net Forums
post #1 of 15 Old 01-23-20, 12:29 Thread Starter
Bmore
Bmore's Avatar
Weird Noises!
Just as the season was ending last year, the bike starting making a terrible noise. I'm finally around to taking it apart, but I'd like any input from you guys.
https://youtu.be/8tUFldG9YvE
hopefully, the problem will be obvious as i take it apart. i'm hoping someone's heard this before and knows what it is.
it's an 07 d675
how to mount your fairings while high (very slowly with errors)https://youtu.be/OQbHxDPLkPM
Bmore is offline
post #2 of 15 Old 01-23-20, 12:59
Razgreeze
Razgreeze's Avatar
I wonder if the starter gear keeps engaging. Does pulling in the clutch change the noise?
Razgreeze is offline
post #3 of 15 Old 01-23-20, 13:31 Thread Starter
Bmore
Bmore's Avatar
i think that it did change the noise slightly... i also noticed that the clutch lever slack disappeared all of a sudden...
Bmore is offline
post #4 of 15 Old 01-23-20, 13:37
Razgreeze
Razgreeze's Avatar
I suspect that it is the clutch. Layman's guess here but I wonder if a spring broke or something. You can make a "mechanics stethoscope" by putting a screwdriver handle in your ear and putting the tip In various areas on the outside of the motor and it will conduct sound much more precisely.
Hopefully it is the clutch, at least that is a reasonable repair and easy to get to.
post #5 of 15 Old 01-23-20, 13:40 Thread Starter
Bmore
Bmore's Avatar
yes hoping so.... in the 20k+ miles i've had it, i haven't needed to change the clutch so maybe it's finally due
thanks for the input
Bmore is offline
post #6 of 15 Old 01-23-20, 14:22
keeena
Hard to tell from the audio. But if your clutch lever is behaving differently: worth having a look.
I mostly came by to tell you that the clutch cover is obnoxious to re-install on these bikes. Pay close attention to the angle you have to tilt it to clear the frame. There's probably some posts on this site with more tips.
keeena is offline
post #7 of 15 Old 01-23-20, 14:49 Thread Starter
Bmore
Bmore's Avatar
was wondering,
there are no good aftermarket clutch kits for these bikes, right?
EBC sells just the friction plates.... so is everyone buying original Triumph clutch parts for clutch jobs?
Bmore is offline
post #8 of 15 Old 01-23-20, 15:10
TTRIgnitionSystems
Site Sponsor
TTRIgnitionSystems's Avatar
On the old FZRs, a suddenly noisy & heavy clutch was an indicator that the push rod had snapped. This was generally caused by insufficient free play in the cable, resulting in the throwout bearing welding itself to the push rod.
I realise these machines use a rather different mechanism, but the failure mode would be the same. The cure is also the same - tear the clutch down, and inspect the throwout mechanism.
TTRIgnitionSystems is offline
post #9 of 15 Old 01-24-20, 08:56
keeena
Yep, I used OEM when I did mine this past spring. Never had a problem w/ OEM clutch bits (generally).
keeena is offline
post #10 of 15 Old 01-24-20, 12:02 Thread Starter
Bmore
Bmore's Avatar
so 37k+ miles total... i assume this wear on the basket is normal.... right? maybe the grooves are a little too deep? would it be causing the noise?
clutch plates look very good, no bluing or warping.
i also took off the valve cover to eventually check clearances. nothing unusual up top so far
Bmore is offline
