LED indicators not working - Triumph675.Net Forums
post #1 of 3 Old 08-02-20, 05:19 Thread Starter
Donald_Trumpy
Hi all.
First time poster, hi. I have a 2007 Daytona 675 and live in Sydney, Australia.
First up, I've searched, but can't find anything which quite fits my query.
I had rear LED indicators (installed by previous owner), and I found the left one wasn't working.
So, I got new ones, and they don't work at all.
There was hyperflashing, but I can't confirm if that is the relay, or the fact one wasn't working.
The flasher loom looks to have two positives and a single ground. The previous indicator negatives were spliced into that common ground.
The spliced ground has continuity, and there is power the the live wires. The indicators work when connected directly to the battery.
So my question is, what could be stopping the new indicators from working?
Note, all tests had the engine off.
Donald_Trumpy is offline
post #2 of 3 Old 08-02-20, 08:11
Stephen Pilsworth
Could very well be a relay, the standard relay was made for the bulb type ones. Anything fancy and it's best to swap seeing as it's a simple plug and play swap.
Don't bother with the triumph led relay, just grab one off eBay and see if that solves the issue
Stephen Pilsworth is offline
post #3 of 3 Old 08-06-20, 13:42
TzaHiko
https://www.rad.eu/nl/c/p/49216-paas...is-208-030.htm
These fitted on my 2014 675 street triple, not sure if it'll fit on yours
TzaHiko is offline
