DIY Race Harness Questions - Page 3 - Triumph675.Net Forums
post #21 of 22 Old 07-01-20, 03:37
alpine 318is
Originally Posted by GoDSaLo View Post
gonna try this asap
Go slow or you'll cut the wrong wire like I did and have to back track 20 steps
2013 Triumph Daytona 675R - Race Bike
https://www.triumph675.net/forum/sho...d.php?t=251173
alpine 318is is offline
post #22 of 22 Old 07-06-20, 15:36
MissedApex
I did similar on my SV650.
I highly recommend buying a spare harness so you can lay it out on the floor. Mark each connector function, and then start marking the wires you want to remove. (and what connector they go to!)
Rather than cutting the harness, de-pin the connector! Then if you need to, you can add the wire back in. If you can't de-pin the connector, then make sure you leave enough of a pigtail that you can solder your connection back in.
MissedApex is offline
