Shift spindle support experiences - Triumph675.Net Forums
post #1 of 5 Old 01-27-20, 18:52 Thread Starter
Sidestash
I recently installed a racetorx shift support after hearing nothing but good things about how much more precise and clean up shifts are. I honestly haven't noticed any difference, just wondering what others have experienced with this mod...
Sidestash is offline
post #2 of 5 Old 01-27-20, 19:58
Newbeme
Newbeme's Avatar
My personal take is I noticed that while aggressive shifting it seems to be a little smoother. Honestly, I have no idea if it is truly smoother or not. For all I know it may just be a placebo affect.
Happier than a seagull with a french fry!
Newbeme is offline
post #3 of 5 Old 01-28-20, 00:37
It makes the biggest difference with race shift stars and older bikes with wear on them. It takes some load off the worn parts. With a race shift pattern and or a rear set with an adjustable travel you can put a lot of load on the shift shaft. However Triumph unlike other brands has had the good sense to put a proper roller bearing on each end the shaft so the benefit may not be noticeable in most situations. If anything it's nice piece of protection in case of a crash it could prevent snapping the shift shaft.
MacBandit is offline
post #4 of 5 Old 01-28-20, 02:02
MGFChapin
MGFChapin's Avatar
My bike had the shift shaft replaced under warranty after only 2000 street miles. No issues since installing a Sato holder in the past 3000 race miles.
MGFChapin is offline
post #5 of 5 Old 01-28-20, 15:13
sergechronos
Pretty much same for me. Original shift shaft failed and was having trouble downshifting within the first couple thousand miles. Had it replaced under warranty, and also switched to a race shift star and added the Sato brace and adjustable rear sets, no issues 4000 miles later.
sergechronos is offline
