Torque wrench? - Triumph675.Net Forums
post #1 of 45 Old 02-17-14, 18:17 Thread Starter
huestmight585
Torque wrench?
Hey guys gonna start warmin up soon so it's time to start tinkering. What's a good torque wrench that's a decent price?
huestmight585 is offline
post #2 of 45 Old 02-17-14, 18:32
GOTJ
I can't recommend a specific brand or model but you will need two. One for the smaller fasteners (max 50 lb-ft) and one for the larger (max 150 lb-ft). Beam-types are the cheapest but harder to read to VERY specific values. Click-types are much more expensive but easy to set the value. One drawback to the click type is that they should be recalibrated periodically but I'll bet there's not one user in one hundred that does so. Beam types are calibrated forever unless used way past their limits such that they get a permanent bend. Sears is the fallback source for tools for a lot of people. I have two of their beam type. If you go click type, don't go cheap.
GOTJ is offline
post #3 of 45 Old 02-17-14, 18:41
aj_day
aj_day's Avatar
I have been pretty happy with Craftsmen torque wrenches. A good balance of price and quality for my own purposes. They also carry a great warranty. Better than cheap home improvement store versions, but not as good as aviation caliber tools. Pay attention to the LOWEST torque rating. Our bikes have bolts with torque ratings down to 7nm. Many torque wrenches only go down to 20nm. The 3/8in craftsman at least goes down to 10nm.
Torque wrench specs can be a rabbit hole. Check a few aviation forums and you will find reams of technical info on reliability and testing standards. If you want to be a torque wrench nerd, go with snap-on, mac, or an aviation specific manufacturer. Expect to spend $300+ per wrench. I am not sure that +/- .01 accuracy is necessary for motorcycle maintenance, but I do recommend steering clear of cheap ones. I stripped the pinch bolt threads in my lower fork leg casting using a sub-par torque wrench.
aj_day is offline
post #4 of 45 Old 02-17-14, 19:22
DecepticonDon
BOTM Marshall
DecepticonDon's Avatar
I bought a $40 clicker from NAPA. Found a DIY test on the net and it checked out just fine.
DecepticonDon is offline
post #5 of 45 Old 02-23-14, 04:34
ChickenStrips
ChickenStrips's Avatar
Its the afternoon on the last day of the holidays and its your call: Reg Lindsay`s Country Homestead with Mum and Dad or a painters plank on the top of a 12 gallon drum and your YZ80E...
ChickenStrips is offline
The Following User Says Thank You to ChickenStrips For This Useful Post:
drummer92 (02-23-14)
post #6 of 45 Old 02-23-14, 09:48
OKStriple
OKStriple's Avatar
Hate to admit it but I use the cheap Harbor Freight torque wrenches.
they work- haven't had a problem.
2009 Matte Graphite Street Triple R. Arrow Slip on's, TecSpecs, GB Racing Protection bundle, CRG Lane Split Mirrors, on Michelin Pilot Road III
7643 posts behind MacBandit and getting further behind each day
OKStriple is offline
post #7 of 45 Old 02-23-14, 10:42
NefRider
NefRider's Avatar
Good thread, I was wondering about this myself. Is Schwaben a good brand?
09 ST3R
09 ST3R
NefRider is offline
post #8 of 45 Old 02-23-14, 10:56
bmw4422
bmw4422's Avatar
I've used them in comparison to Stanley Proto before, and the 1/2" one was spot on when looking at settings for higher amounts such as wheels. I'm not sure if I'd trust it for lightweight specs though. Not sure how good their quality control from item to item is.
Brian
2011 daytona 675 SE (sold)
bmw4422 is offline
post #9 of 45 Old 02-23-14, 10:57
Zaph
Zaph's Avatar
I had a crasftsman and it fell apart. Now I have a Harbor Freight and it's reliable as hell. (both click style) Ironic isn't it?
Key to sucess with these is to use them at 70 degrees, and crank the torque setting down to zero before you store them.
If you use these wrenches cold, you are over torquing bolts. And if you don't set them back to zero, they loose their calibration.
Zaph is offline
post #10 of 45 Old 02-23-14, 11:56
Hokie
Hokie's Avatar
You are only supposed to use a torque wrench in the middle 80% of its range. A 1/2" wrench is too much for anything other than wheels and the other big torque bolts. 3/8" is what you need for 99% of the bike.
Hokie is offline
