Camping - Triumph675.Net Forums
Trip reports Been on tour? Tell everyone about it here. Old threads may later be moved to the regional forums.
post #1 of 13 Old 07-10-16, 23:58 Thread Starter
s.imani
s.imani's Avatar
Camping
Anyone do any camping with the Daytona675 ?
Here's some photos of my recent trip
2015 Daytona 675 a.k.a. Sia - Toronto, Ontario
s.imani is offline
post #2 of 13 Old 07-11-16, 10:23
Plasmablaster
Plasmablaster's Avatar
Ahhh I'm so jealous. The second epitome of motorcycling spirit. (The first one is trackdays and/or races of course). I used to do that a lot sometime ago but now the missus wants soft sheets and walls.
If you do that regularly I'd suggest getting side railings & bags. Improves handling A LOT - the height difference of the CoG position of all that heavy gear makes a world of difference. I bet when loaded-up like this the bike goes like a boat doesn't it?
Plasmablaster is offline
post #3 of 13 Old 07-11-16, 20:50 Thread Starter
s.imani
s.imani's Avatar
Thanks @plaamablaster. Do you know of any one that actually makes specific sidebars and railings for this bike, or just the generic ones you're suggesting ?
FYI. That big bag in the bag is a 100Litre bag. I stuffed it, and it weighd about 55lbs when she all ready to be strapped down
s.imani is offline
post #4 of 13 Old 07-12-16, 20:47
Plasmablaster
I didn't make any distinction between bike- specific or generic ones. GIVI makes bike-specific railings for the ->'12 STR, I know because I've got them on my bike. Sorry if nobody makes any for the 13+ Daytona but you can make your own if you can weld - I made a pair for my SV650. You just need to spend a day or two cutting, bending, welding and painting. Alternatively you can have them made but I guess it's going to be expensive and you'll have to find someone willing to experiment a bit.
That's a lot of weight by the way. What did you pack in there? A woman perhaps?
post #5 of 13 Old 07-12-16, 21:17
kisertn
kisertn's Avatar
But it weighs significantly less and sits lower than a pillion rider would. So, what's the issue really? Seems to me that the weight should be a non-issue. I also have a 60-liter tail bag, similar to the OP's and I had no issues on a long trip with about 35 pounds in it. It rode fine on my 675R.
kisertn is offline
post #6 of 13 Old 07-13-16, 07:17
Plasmablaster
If you can enjoy your bike this way, good for you and I envy you. I pretty much forget sporty riding pleasure with any significant weight placed on the pillion's seat. Change of direction characteristics change so much that I just don't enjoy it. Maybe it's because I only weigh 64 kilos, maybe not.
The issue of pillions affecting bike handling less than their weight would suggest has puzzled me too. It probably has to do with the pillion being flexible and not exerting rotation moment forces as high as rigidly-attached weights.
post #7 of 13 Old 07-13-16, 08:58
kisertn
kisertn's Avatar
Oh, I am in no way trying to say that such a weight has no impact on how the bike performs; absolutely it does. I guess I just wasn't thinking about a camping trip and 'sporty' in the same context. If you want a sporty ride, while camping, then a different solution would likely be needed. When I wore my weight I was just doing straight up/down riding until I reached my destinations and then pulled off the anchor and went riding without. Completely agree that such a weight will change things.
kisertn is offline
post #8 of 13 Old 07-28-16, 01:13
mark-up
mark-up's Avatar
Good to hear about another sportbike camper!
I motorcycle camped when I had my FZR600. I used a tank bag and throw-over saddle bags having tops that rose above the pillion perch. That created a channel where I could stack my tent, bedroll and bag in a north-south pyramid. My equipment was all backpacking stuff so it was small and light in weight. For various reasons, I had to get rid of my gear, so my recent trips have all been motel/hostel affairs.
mark-up is offline
post #9 of 13 Old 09-03-17, 19:43 Thread Starter
s.imani
s.imani's Avatar
Did this for a third time ! Here's some photos from this long weekend.
Review: It was all in all alright I just have a continuous problem strapping down the bag to the bike securely without having it slide forward into my back. Otherwise the weight is fine......the bag and equipment is about 65lbs in total. I'd do it again.
Sent from my SM-G935W8 using Tapatalk
s.imani is offline
post #10 of 13 Old 09-04-17, 23:42
mark-up
mark-up's Avatar
Of course your bags are sliding -- you must be at the equator because the ground and your bike are vertical!
All I ask is a Hinckley triple
And a road to steer her by.
mark-up is offline
Hybrid Mode Hybrid Mode
