Headlights not working - Triumph675.Net Forums
post #1 of 2 Old 09-27-20, 12:01 Thread Starter
Bigtimecc
I have a 2007 Daytona Triple and last night my headlights stopped working. Bulbs aren’t blown, fuse is good. The high beam indicator is stuck on but there’s no lights. When I remove the H9 bulb the indicator goes off. I’ve put in new bulbs and fuses just in case and I still do not have light. I’m lost now does anyone have any suggestions on what else I should check?
Bigtimecc is offline
post #2 of 2 Old 09-28-20, 07:20
Chirp
Electrical gremlins are the worst to diagnose. The proper way to do this is to sit down with the wiring diagram and a pencil and trace all the pathways to and from the bulb, switch, etc. Budget 3 hours. That said, I'd start by spending $20 and replace the relay and double check all the multi-connectors I could reach. And maybe spray WD40 on the high/low switch and toggle it it back and forth for a while.
Chirp is offline
