reset the service required indicator - Triumph675.Net Forums
post #1 of 12 Old 06-17-18, 12:35 Thread Starter
Allworld
Allworld's Avatar
I want to apologize if this is posted already but I haven't been able to find it.
I just picked up a used 2015 Street Triple R, the bike has 7K miles on it and so I change the oil and filter, ...
I want to reset the service required/ maintain indicator. I figured this would/is a simple, but when you don't know ....... not so simple.
Allworld is offline
post #2 of 12 Old 06-17-18, 13:58
ramnakhle
ramnakhle's Avatar
Canít do it without diagnostic / dealer tool.
Crappy but true.
ramnakhle is offline
post #3 of 12 Old 06-17-18, 16:24 Thread Starter
Allworld
Allworld's Avatar
Thanks can I just buy a diagnostic tool ... Harbour Freight..Autozone??
Allworld is offline
post #4 of 12 Old 06-17-18, 20:57
Gosling 1
Here is a link to the Dealertool website, I'm using it on my 2014 Street Triple R. Never tried a generic diagnostics tool.
https://dealertoolcouk.ipage.com/
Gosling 1 is offline
The Following User Says Thank You to Gosling 1 For This Useful Post:
Shamrock (06-17-18)
post #5 of 12 Old 06-17-18, 22:24
Shamrock
Mean Green Mod
Shamrock's Avatar
No, it has to be specialized to a Keihin ECU. Only dealertool, as Gosling 1 said, or TuneECU.
*NOTE* Dealertool comes with the OBDII cable, TuneECU does not.
Dealertool will do more than just reset that little wrench. It can balance your throttle bodies, prime your ABS pump, clear any code, etc.
Shamrock is offline
post #6 of 12 Old 06-18-18, 00:36
If you have an Android device you TuneECU will do a lot of the service stuff for a lot cheaper than DealerTool.
MacBandit is offline
post #7 of 12 Old 06-18-18, 01:23
Shamrock
Mean Green Mod
Shamrock's Avatar
But don't you need the OBDII dongle, or a bluetooth device to plug in?
Shamrock is offline
post #8 of 12 Old 06-18-18, 01:36
Correct. Both require some device to connect to the ECU and communicate with and the device itself is relatively inexpensive.
Something else to consider is that the actual mileage for the service reminder can be set by the dealer. You could just have them max out the miles and basically turn it off.
post #9 of 12 Old 06-18-18, 15:08 Thread Starter
Allworld
Allworld's Avatar
Thanks gents, so basically I need a laptop, cable and software...
The only Android device I have is my phone.
Allworld is offline
post #10 of 12 Old 06-18-18, 16:12
Kevin7909
I use tunecu lite on my phone and it works fine. Lite is all you need to do diagnostics, reset the service light, bleed the brakes, etc.
Kevin7909 is offline
