Key Sheared off in Gas Tank - Triumph675.Net Forums
post #1 of 5 Old 02-24-20, 02:38 Thread Starter
gngsta5311
Finally some nice weather in NJ, take my bike out ride to the gas station, bout to fill her up with premium and go to open the tank and nothing, key breaks off in my hand. Lovely.
Any ideas suggestions for either
A. getting it out of their (i tried some needle nose pliers and will be calling a mechanic friend tomorrow to see if he has ideas).
B. replacing or fixing the difficulty in turning the key. I plan on getting some graphite fluid for the lock once the broken key is out.
Thanks
gngsta5311 is offline
post #2 of 5 Old 02-24-20, 09:04
TTRIgnitionSystems
Site Sponsor
TTRIgnitionSystems's Avatar
You may need a locksmith for this mess ...
TTRIgnitionSystems is offline
post #3 of 5 Old 02-25-20, 14:43
Dirk777
Try to extract the broken part with a jigsaw blade! Did this on several locks in the past 40 years.
Good Luck!
Dirk777 is offline
post #4 of 5 Old 02-26-20, 10:55
GMike278
GMike278's Avatar
For what it's worth (and hopefully not violating a forum rule) Soldier113 is selling a new uncut key blank in the classified section. ;)
GMike278 is offline
post #5 of 5 Old 03-03-20, 21:05
Pathfinder
Pathfinder's Avatar
Try a hot glue gun glue stick. Melt just the end, press it onto the broken key, let harden. Then pull key out
If you can't stand behind our troops, please, stand in front of them!
Pathfinder is offline
