Daytona 675 sitting for 3 years; list to get up and running?? - Triumph675.Net Forums
post #1 of 6 Old 01-27-20, 10:58 Thread Starter
itsMeanMuggin
Question Daytona 675 sitting for 3 years; list to get up and running??
Hello everyone!
Long time rider, first time Daytona owner. I just picked up a '09 Daytona 675 Triple. It's been sitting in a garage for the past few years. Has about 5k miles on it.
Was curious what all I needed to clean/change/check to get it back in prime condition.
So far I have changed the oil, new filter, and new battery. I'm seeing that it needs a new chain/sprocket/tires. To note, it will crank but not start, so I plan to check the spark plugs/injectors.
Is there anything else I should add to my list??
Thanks!
itsMeanMuggin is offline
post #2 of 6 Old 01-27-20, 11:21
subaruzi
subaruzi's Avatar
Check gas for rust. I'd look to change fuel filter
Sent from my moto x4 using Tapatalk
subaruzi is offline
post #3 of 6 Old 01-27-20, 21:03
Newbeme
Newbeme's Avatar
Tires for age and they may be flat spotted after sitting so long.
Happier than a seagull with a french fry!
Newbeme is offline
post #4 of 6 Old 01-27-20, 21:06
subaruzi
subaruzi's Avatar
Get a Shorai or similar battery. Makes all the difference.
subaruzi is offline
post #5 of 6 Old 01-28-20, 03:07
MGFChapin
MGFChapin's Avatar
All fluids. You've already done the oil, but the coolant, brake fluid, fuel and suspension fluid need to be dumped ASAP. +1 to checking the gas tank and changing the filter and +1 to new tires.
The injectors are a good idea and if you're pulling them, it also means the fuel rail will be drained which is also a good thing. When you put new fuel in, make sure it's something with a good detergent like Techron or add your own, like K100.
MGFChapin is offline
post #6 of 6 Old 01-28-20, 10:37 Thread Starter
itsMeanMuggin
Good call on the fluids; since it wont turn over, i was going to check the injectors/spark plugs
Edit: Also any leads on a fuel filter? havent had much luck when searching.
