How to change spark plug? - Triumph675.Net Forums
post #1 of 5 Old 08-26-12, 15:03 Thread Starter
Renejr40
Renejr40's Avatar
Send a message via AIM to Renejr40
Hello,
was looking through the stickies to see if there were any pic-by-pic action of how to change the spark plugs on a Daytona 675, but with no luck.
Can someone point me in the right direction please?
Renejr40 is offline
post #2 of 5 Old 08-26-12, 15:07
tooblekain
tooblekain's Avatar
It's pretty easy...
Remove the tank
Unhook connection to stick coils
Pull stick coils out (no tools needed)
Now you have access to remove spark plugs
Use spark plug remover socket
tooblekain is offline
post #3 of 5 Old 08-26-12, 15:31 Thread Starter
Renejr40
Renejr40's Avatar
I see, but where and what are the stick coils? Do I need to remove the air filter?
Renejr40 is offline
post #4 of 5 Old 08-26-12, 16:29
tooblekain
tooblekain's Avatar
yes, you will need to remove the airbox
post #5 of 5 Old 08-26-12, 18:01
TwoWheeledWonder
Noob Hazer
TwoWheeledWonder's Avatar
Here I started to make a how to, and then stopped because I really didnt care, but here are some pictures.
After taking the tank and air box off, you will see those plugs, they are a ***** to pull out, but they come out. Then just screw the plugs out. And for torque specs just do a search on here and there is a thread with all the torque specs for our bikes.
Also a good time to clean up around there, it gets dirty, so I cleaned it all off when I got my plugs changed out.
2010 TornadoRed D675 Trackbike
TwoWheeledWonder is offline
