09 D675, intermittent no power to dash/no start. - Triumph675.Net Forums
post #1 of 3 Old 03-10-20, 21:20 Thread Starter
divune
Hi all. My 09 Daytona 675 has recently developed an issue where upon key on, the dash will not power up, nor does the pump and etc prime. The turn signals and brake lights will work in this position, just no dash and will not start. Usually waiting 10 minutes or so it will resolve.
I have the r/r upgraded with the newer triumph part & adapter harness, and the battery is 1 year old along with it. Charges fine ~14v, and the battery holds voltage as well. I've gone through all the connectors as well as the ones behind the dash with no improvement. Any specific items anyone may know of causing this?
divune is offline
post #2 of 3 Old 03-10-20, 21:39
subaruzi
subaruzi's Avatar
Kill switch faulty?
That happened to mine.
Sent from my moto x4 using Tapatalk
subaruzi is offline
post #3 of 3 Old 03-11-20, 11:25
ramnakhle
ramnakhle's Avatar
Check your wiring and harnesses for any kinks.
Also try to move the handle bars left/right with the key on and see if it affects anything.
I recently had a problem where everything is normal on dash, and if I hit the starter switch nothing happened unless I turned the handle bars to the left.
Turned out to be a kink in a mis-routed harness resulting in a cut wire. The ends would come together when I turned the handle bars and make contact to start the bike.
Soldered
Shielded
Fixed
ramnakhle is offline
