Changing hoses - Triumph675.Net Forums
post #1 of 7 Old 11-08-19, 09:41 Thread Starter
jollyrog3r88
jollyrog3r88's Avatar
Changing hoses
Hey guys,
I noticed this year that the bike was running a little hotter with distilled & water wetter mixed. I should say the bike is not overheating & fan is working normally.
Was thinking about changing out the radiator hoses to see if that helps - has anyone had any success with that or would changing hoses be a waste of time? They are original on a 2012 675R. Are there any other benefits to swapping hoses?
Any other suggestions are welcome.
Thanks
jollyrog3r88 is offline
post #2 of 7 Old 11-08-19, 15:18
MGFChapin
MGFChapin's Avatar
I didn't notice any drop in temp when I switched to Samco hoses.
I run Water Wetter too and the additive seems to have a pretty short lifespan; when I change it out after 6 months it's no longer pink. Change it often, and make sure you have no air in the system.
I did find a higher pressure radiator cap that lowered temps a bit. You might try that $15 mod before dropping lots more on fancy hoses.
MGFChapin is offline
post #3 of 7 Old 11-08-19, 19:06 Thread Starter
jollyrog3r88
Thanks - do you have a link to one of the radiator caps you're talking about?
Because of winter I have to switch between coolant & distilled, so I'll keep an eye on it next season. I have a feeling I probably skimped a little with the water wetter mixture as well.
post #4 of 7 Old 11-08-19, 19:16
MGFChapin
MGFChapin's Avatar
https://www.powersportsuperstore.com...-cap-23psi-red
More isn't better. Add as much as the directions tell you, which for our cooling systems I think is like 2 oz.
jollyrog3r88 (11-09-19)
post #5 of 7 Old 11-10-19, 16:09 Thread Starter
jollyrog3r88
Thanks. Yeah I think I double guessed myself as I was watching an STG video using WW pre-mixed and it said it was 50/50 mix.
post #6 of 7 Old 11-15-19, 07:22
cyclesailor955
Engine Ice
Engine Ice is Better.
It is safe for track usage and cold weather protection.
Change your coolant every 2 years.
cyclesailor955 is offline
post #7 of 7 Old 11-15-19, 08:40
Renboy
Renboy's Avatar
If you're talking about Royal Purple then no it isn't. You can't use it on track because it's not supposed to be mixed with just water. You need to mix it with coolant, and at the track, that's a no no.
Renboy is offline
