Reposition regulator with track fairings - Triumph675.Net Forums
Track Days Track days and other non-racing related track events
post #1 of 5 Old 05-23-20, 14:04 Thread Starter
jollyrog3r88
jollyrog3r88's Avatar
Hi guys,
I'm in the middle of fitting together track fairings and would like some input on where/ how you mounted the regulator within the fairings, given that I don't want to drill additional externally facing holes on the upper fairings.
I am thinking just drilling the inner fill and attaching via bolt.
My other thought was wanting to make sure it had enough airflow.
Bike is a 2012 R, if that makes any difference.
Cheers
jollyrog3r88 is offline
post #2 of 5 Old 06-16-20, 21:06
Tmccustoms
Tmccustoms's Avatar
I bolted mine to the inlet tunnel. Only been to track once but it worked well. I’m not sure the short time on the track is enough to cause overheating issues.
Tmccustoms is offline
post #3 of 5 Old 06-17-20, 10:16
keeena
Originally Posted by Tmccustoms View Post
I bolted mine to the inlet tunnel. Only been to track once but it worked well. Iím not sure the short time on the track is enough to cause overheating issues.
Mine is the same and have seen it this way on other Daytonas.
keeena is offline
post #4 of 5 Old 06-17-20, 13:44 Thread Starter
jollyrog3r88
Nice,
I ended up bolting it against the bottom of the nose cone which worked well enough. I figured a couple of small gaps between the intake and windscreen would provide enough airflow. No issues so far!
post #5 of 5 Old 06-17-20, 17:17
GoDSaLo
Gonna try it Thanks
GoDSaLo is offline
