Oil Pump Removal and Install How To - Page 3 - Triumph675.Net Forums
post #21 of 25 Old 04-19-19, 22:28 Thread Starter
Ah, yes. Triumph has some weird notations and honestly the worst parts fiche for any brand I was ever worked on and that includes Hyosung with poor translations and classic BMW which was all in German.
post #22 of 25 Old 09-07-19, 02:47
OzMoto
OzMoto's Avatar
Originally Posted by MacBandit View Post
Quick how-to on how to change the oil pump and specific information on installing the new style pump in older models. For more info on the changes to the pump see this post.
Next you need to unbolt and pull out the coolant pipes from the motor. There is one in the front next to the oil filter and one just below the countershaft sprocket.
I've got a slight oil leak from this tube - my guess is the o-ring. Can I get away with just removing this pipe / swapping the oring without dropping the oil pan etc?
Ride carefully - You are invisible.
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R | SC-Project CF Oval Silencers | Triumph Quickshifter | 520 Conversion (-1 front)
RIP: 2003 CBR600RR
Sold: 2012 CBR250R | 2000 NSR150SP
OzMoto is offline
post #23 of 25 Old 09-07-19, 11:43 Thread Starter
Youíll need to remove the oil pan just to ensure you get the pipe fitted back together correctly. Also when you remove it youíll dump a bunch of water into the sump.
post #24 of 25 Old 09-09-19, 06:42
OzMoto
OzMoto's Avatar
Aw crap. So it is oil and coolant drop to do it then. FML.
RIP: 2003 CBR600RR
OzMoto is offline
post #25 of 25 Old 09-09-19, 09:52 Thread Starter
Yes both.
The Following User Says Thank You to MacBandit For This Useful Post:
OzMoto (09-11-19)
