Losing power on acceleration - Triumph675.Net Forums
post #1 of 9 Old 09-17-19, 18:28 Thread Starter
iadminko
iadminko's Avatar
Unhappy Losing power on acceleration
Greeting ladies and gentlemen,
I'm experiencing a very strange issue with my Street Triple R:
When I'm in a city riding mode (calm commute) the bike is fine.
But in case if I'm doing the long accelerate, for example entering highway, it suddenly drops the RPMs pretty hard and i'm getting all my weight to my arms. Sometimes the engine can stall after accelerating in a corner in that moment, when i switch the gear.
It looks like that (13-14 sec)
https://youtu.be/Q18-n-33Pdo
I don't switch or drop the throttle at that moment.
To me it loses the gas or spark at some point and then going on again.
I've checked the oxygen sensor (replaced with the working), didn't help. Spark plugs and coils look ok. Air filter is replaced.
What else it could be?
Thanks everyone in advance for all ideas!
iadminko is offline
post #2 of 9 Old 09-17-19, 23:11
ramnakhle
ramnakhle's Avatar
Do you have a quickshifter installed?
ramnakhle is offline
post #3 of 9 Old 09-18-19, 09:56 Thread Starter
iadminko
iadminko's Avatar
No QS there.
iadminko is offline
post #4 of 9 Old 09-18-19, 00:51
Stephen Pilsworth
Check the fuel hose for any kinks as you lower the tank.
Sent from my Nokia 7.1 using Tapatalk
Stephen Pilsworth is online now
post #5 of 9 Old 09-18-19, 09:57 Thread Starter
iadminko
iadminko's Avatar
Was checking yesterday - looks fine.
iadminko is offline
post #6 of 9 Old 09-18-19, 10:31
cdenley
Did you check your ground cables on the frame and battery?
Chris Denley
CCS Midwest Amateur #212
fb.me/DenleyRacing
cdenley is offline
post #7 of 9 Old 09-18-19, 10:43 Thread Starter
iadminko
iadminko's Avatar
Hmmm, i did not.
Do you think it could be a random disconnection?
The issue comes up only if i accelerate pretty hard. And only when i'm riding. I did a test in garage with wheels off the ground - no glitch.
So the bike must be loaded with some weight and accelerate harder than a city ride.
iadminko is offline
post #8 of 9 Old 09-18-19, 11:11
cdenley
Originally Posted by iadminko View Post
Hmmm, i did not.
Vibration can cause loose electrical connections to lose connectivity briefly resulting in brief loss of power. I've had that happen to me and seen it happen on track, although not on a Triumph.
Chris Denley
fb.me/DenleyRacing
cdenley is offline
Hybrid Mode Hybrid Mode
