Engine stands? - Triumph675.Net Forums
post #1 of 38 Old 11-11-19, 15:54 Thread Starter
GMike278
GMike278's Avatar
Engine stands?
Reroll's teardown thread and MGFChapin's awesome response got me thinking about engine stands. I've seen some universal stands for sale online and was wondering if anyone had one that worked for the 675 / 765 motors. (verses getting creative welding up some tubing / wood etc).
Cheers,
Mike
GMike278 is offline
post #2 of 38 Old 11-11-19, 16:54
I've been barking up that tree for years. If we don't get an answer, we need to find someone with a loose spare motor and get a few stands welded up.
I have a stand from Tyga that I absolutely love, for my NSR250. Something similar for the 675 would be so much better in the shop than wood blocks. We just need dimensions for the engine mounts and I can ask a few different local welders for quotes.
post #3 of 38 Old 11-11-19, 17:08 Thread Starter
GMike278
GMike278's Avatar
I'd get in on that for sure! (c'mon welders on the forum)
I was looking at this one:
I like that it allows you to rotate the motor around but really I just want something like the Tyga. (also not sure if the one above would mount up to a 675.)
GMike278 is offline
post #4 of 38 Old 11-11-19, 17:13
That's pretty trick, but it'd be more expensive to build and to ship. The Tyga stand allows you to stably tilt the engine onto either pair of legs, so you could do essentially the same jobs as the fancy rotating stand.
post #5 of 38 Old 11-20-19, 16:57
Came across this homemade one on Facebook. The guy is in the UK, but I asked if we can get specs. I'm also working with a domestic welder to see if we can make a batch of reasonably-priced stands. We'll see.
post #6 of 38 Old 11-20-19, 23:27
keeena
Following this thread because I've been interesting in finding or designing a stand. This became a "thing" over the last year as I helped a friend tear down 3 D675 motors. :) I generally like the idea of something that is adjustable so it can be used on multiple motors.
I've seen that rotisserie-style before but it looks a bit too hokey to me.
My friend and I were thinking about designs which would bolt up to an automotive engine stands to leverage the rotating function. I was also thinking of designing it in a way that it could still function as a regular bench stand..it would just have the provision of bolting to the standard engine mount plate.
The one MGFChapin posted is in the direction I was thinking; I like the fact that the design could accommodate rear mounts with different fore/aft locations. But height and width are also something I'd want to address. For the first: I think using a joint on the frame-side attachment (instead of the threaded rod straight thru the box tube) would allow for a range of rear engine mount heights. Similarly, a heim joint on both ends would give a bit of width adjustment. I feel the adjustable support arms width is important because they should attach as close to the motor as possible.
keeena is offline
post #7 of 38 Old 11-21-19, 09:15 Thread Starter
GMike278
GMike278's Avatar
EXACTLY what I'm looking for!
GMike278 is offline
post #8 of 38 Old 12-03-19, 12:11 Thread Starter
GMike278
GMike278's Avatar
Ended up breaking down and ordering this one from K&L Supply. Amazon had it for 200 bucks (which yeah, is pricey but better than having a spare factory race engine laying around on the floor)
Pros: Well made and I like that you can rotate the motor to work on it. Can be used for multiple engine designs.
Cons: It was a royal pain in the a** to get up on the stand. I set the motor on some blocks of wood and leveraged it up. Sure would have been nice to have an extra set of hands. Secondly, not sure how much I trust the motor being supported from only the bottom. (Lets see how much weight that long rear stock bolt can handle before it snaps. ¯\_(ツ)_/¯ )
(photo for demonstration - I'm NOT leaving it like this)
I would STILL love a stand like the one MGFCHAPIN posted (and continue to use this one for engine servicing) -wink wink- c'mon Paul, hook a brother up! :P
GMike278 is offline
post #9 of 38 Old 12-03-19, 16:04
TheBeerHunter
TheBeerHunter's Avatar
What exactly does that stand mount to on the motor? Im thoroughly confused.
TheBeerHunter is offline
post #10 of 38 Old 12-03-19, 20:28 Thread Starter
GMike278
GMike278's Avatar
The stand has those adjustable arms with a hole in the end - you line them up with the mounting points on the engine and bolt it up. Pretty straightforward. (I'm using a spacer with the stock rear mounting bolt, which might be what is throwing you off) ;)
GMike278 is offline
