2016 STR front side panel removal - Triumph675.Net Forums
post #1 of 5 Old 10-13-19, 15:21 Thread Starter
moorbeckj
Anyone know how to remove the side panels on this model? Or have a link to instructions?
Jeff Moorbeck
Milwaukee, WI
'16 Street Triple R
'14 Tiger 800
moorbeckj is offline
post #2 of 5 Old 10-13-19, 15:25
TrampusP International
Do you mean the radiator shrouds? If so, yes. If you’re referring to something else, please explain.
There’s a few h5 (I think 5...maybe h4?) Allen bolts holding the shrouds on. I’ll be removing mine later today or tomorrow to flush the rad fluid and can take some pics/video if you need.
TrampusP International is offline
post #3 of 5 Old 10-13-19, 18:15 Thread Starter
moorbeckj
Yes, the shrouds I can find 2 5mm allen bolts but I cannot figure out how the red accent panels come off? I need to get at the electrical connector for the heated handgrips on the right side. Also, there appears to be some sort of phillips head thing too. But it just spins when I turn it. It doesn't back out at all.
Jeff Moorbeck
Milwaukee, WI
'16 Street Triple R
'14 Tiger 800
post #4 of 5 Old 10-13-19, 18:18
Loosen the bolt that holds the indicator on to get the red part of the cowl off.
The Phillips head has a 5mm going into it.
post #5 of 5 Old 10-23-19, 09:21 Thread Starter
moorbeckj
Thanks! The 5mm indicator bolt was the trick.
Jeff Moorbeck
Milwaukee, WI
'16 Street Triple R
'14 Tiger 800
