Cracked Head - Triumph675.Net Forums
post #1 of 6 Old 08-09-19, 09:21 Thread Starter
Vince Accardo
Cracked Head
I’m looking for thoughts on what I found in my 09 Daytona. There was water in the oil so I knew it would be bad, but the cylinder head is cracked on the timing chain side(where the bolt goes through the side of the head). What do you think would have caused that failure point?
Vince Accardo is offline
post #2 of 6 Old 08-09-19, 09:22 Thread Starter
Vince Accardo
Pics of the crack
ID:	250457   Click image for larger version
post #3 of 6 Old 08-09-19, 10:36
Arawn
Frozen coolant.
Arawn is offline
post #4 of 6 Old 08-09-19, 14:41 Thread Starter
Vince Accardo
Makes sense, thanks Arawn. Quick question, are the only differences between the 2006-2008 and 2009-2012 motors in the head? I’m thinking about looking for a complete motor from a 2009-2012 bike rather than just the head by itself. That way I’ll have a spare short block. I know there was a difference in the cam chain hydraulic tensioner, but if I were to run a manual tensioner that would fix that.
post #5 of 6 Old 08-10-19, 07:01
Plasmablaster
Plasmablaster's Avatar
Oil/water pump is different too. It was changed to address some issue with the older pump that gradually damaged the heat exchanger (due to pressure pulses) at high revs. Only relevant for race or frequently tracked bikes.
Plasmablaster is offline
post #6 of 6 Old 08-10-19, 09:54
Arawn
Next time fill it up with antifreeze; IMHO there is no reason to run distilled water in the street.
Arawn is offline
