Will turn over but won't start - Triumph675.Net Forums
post #1 of 2 Old 08-08-19, 16:56 Thread Starter
Wesley Alexander
Dropped the bike a couple weeks ago and started having issues. Replaced the air filter, did an oil change, new battery, and put new fuel in the tank. I turn the key and try to ignite and it turns over but will not crank no matter what. Any advice helps
Wesley Alexander is offline
post #2 of 2 Old 08-09-19, 11:34
cdenley
Do you have spark? No check engine light? I would check the crankshaft position sensor first, since I've had that fail twice causing crank but no spark with no CEL. Since it was dropped, you can check the tip-over sensor, but I think that would cause a CEL.
Chris Denley
CCS Midwest Amateur #212
fb.me/DenleyRacing
cdenley is offline
