2012 675 wont rev past 10K - Triumph675.Net Forums
post #1 of 12 Old 07-24-19, 12:45 Thread Starter
Keith Stone
hi guys.. sorry if this has been covered already..
i have a 2012 675.. it suddenly wont rev past 10K.. no code present.
i have had the dealer flash the ECU.. but that didnt help.
its been a track bike all its life...
about 4 years ago, it wouldnt start after the winter, i brought it in and they replaced the stator.
anyone ever hear of this ?
Keith Stone is offline
post #2 of 12 Old 07-24-19, 14:19
hzhong456
I think I read somewhere on this forums (at some point) that this issue can be caused by the clutch switch being bypassed or removed. Have you checked your clutch switch on the lever?
hzhong456 is offline
post #3 of 12 Old 07-24-19, 15:09 Thread Starter
Keith Stone
i thought i saw something like that as well..
I am going to try that next track day.. im going to bypass the kstand switch and then the clutch switch..
i just dont understand how that could cause it, but i will try.
just figured id put it out here to see if anyone has actually come across it
post #4 of 12 Old 07-25-19, 00:30
MacBandit is offline
post #5 of 12 Old 07-25-19, 08:48 Thread Starter
Keith Stone
https://www.triumph675.net/forum/showthread.php?t=52296
Check your intake flapper if itís staying closed then itís likely the clutch switch.
ok..
where is the intake flapper? do i have to lift the tank?
so there is no way to bypass the clutch switch to determine if it is the problem ?
thanks for the info !!
post #6 of 12 Old 07-25-19, 09:24 Thread Starter
Keith Stone
apparently its item # 15 in this diagram..
so its in the front intake ?
post #7 of 12 Old 07-25-19, 10:15
Shine a light down the intake itís easy to see.
Yes you can bypass the clutch switch. But you need a toggle switch if you want to bypass it all the time as you have to actuate it for the ecu to work properly.
post #8 of 12 Old 07-25-19, 11:03 Thread Starter
Keith Stone
so in terms of diagnosis
can i just unplug it and jump it? what does the computer expect to see when the clutch is out? open or closed contacts?
post #9 of 12 Old 07-25-19, 11:06
It wants to see it closed to start and then open circuit to run.
Thereís no need to do that though. Just look down the intake and see if the flapper opens when you rev it. If it doesnít then itís most likely the clutch switch or the flap actuator or part of its operation.
post #10 of 12 Old 07-25-19, 13:09 Thread Starter
Keith Stone
ok..
i will do that !!!
thanks !
