RC213V MotoGP replica exhaust tip - Triumph675.Net Forums
675 Photos Pictures and more pictures!!!
post #1 of 4 Old 08-03-17, 23:28 Thread Starter
TimeAttack
I'm fairly sure no one has done this before.
It's as loud as it looks, but I've got a little baffle in the mail that will hopefully help kill a few DBs.
TimeAttack is offline
post #2 of 4 Old 08-04-17, 10:21
TwistyWristy
TwistyWristy's Avatar
I miss my old CRX! Looks like a clean one in the background
TwistyWristy is offline
post #3 of 4 Old 08-04-17, 11:01
Bamboo671
Bamboo671's Avatar
I like it! It's welded so how will the baffle be inserted? Will you have to cut and re-weld or just insert from the header end?
Check my sig for my "build". I have the Arrow Race Conical being mocked up for my Daytona. Super stoked about it!
"Win or learn...never lose"
Bamboo671 is offline
post #4 of 4 Old 08-04-17, 15:46 Thread Starter
TimeAttack
The tip isn't welded to the under tail mid pipe so it is removable. The mid pipe slides into the inlet of the tip, it's set up to be held on with two springs but I'm waiting on a couple tabs before I can add the springs.
So to install the baffle, I'll have to just pull the two pieces apart by hand and insert the baffle, then plug them back in together. It'll all eventually be held together with spring tension but for now it's fine since the pipe fits in really solid with no movement.
