2012 Daytona675R hesitation on 5000 RPM - Page 2 - Triumph675.Net Forums
post #11 of 15 Old 01-06-15, 02:46 Thread Starter
ora
ora's Avatar
Unhappy
You removed the idle stepper motor? Are you using a manual idle adjuster?
Nah.I have not using a manual idle adjuster. I only remove servo motor and using full exhaust system(without EXUP in mid-pipe). Another thing I can feel is after I disable EXUP in tuneECU, I can feel the bike idle lower than before(working temperature). When I wait for red light, bike's rev is lower than 1100RPM (dropping and climb up). It sounds like engine about to stop. But when I enable EXUP function in TuneECU. It doesn't happen.
ora is offline
post #12 of 15 Old 01-06-15, 21:53 Thread Starter
ora
ora's Avatar
Thumbs up
Originally Posted by jdgun_13 View Post
Shoot me a PM and i will send you a map that should take care of your problems.
Full akra, bmc filter, free mods.. will allow you to pull off all the BS on the bike.. (emissions, exhaust servo, flapper, sai)
THX BUDDY. I have try ur map yesterday. With Disabled SAI & O2 sensor. TPS reset done. The hesitation gone. Poping gone as well. I know the poping can be turn off when I disable the SAI. I think the O2 sensor is the reason for hesitation.
I gonna do dyno later this month. I think O2 sensor is important for DYNO, what should I do about it? When I disable O2 sensor, the closed loop light never come on, is it play a big role in whole system?( ignition system or ECU manage A/F ratio?). Sorry, I am noob at this part, just wanna figure out what is going on here. Thank you very much.
ora is offline
post #13 of 15 Old 01-08-15, 08:38
jdgun_13
jdgun_13's Avatar
Good to hear the bike is working again.
as for the O2, if you run a custom tune there really is no need for them.
I was told to take it out by my tuner.
Been told that every time I get my bike tuned (different bikes), and with my old RSV4 & 1098 the performance computers do not use them either.
Most of you people are not capable of being your GD self, to damn worried about being politically correct.
2011- Triumph Daytona 675R
2005- Kawasaki ZX-10R
2003- Kawasaki ZX-6RR
jdgun_13 is offline
post #14 of 15 Old 01-08-15, 08:57 Thread Starter
ora
ora's Avatar
Thank you once again buddy. I just realized that I have installed Bazzaz Z-FI unit previously(because some stupid reason, I don't know tuneECU at that time). I think this unit will interfering with my ECU, which means it will interfering the map I load into ECU. Is this the possible reason cause my hesitation before? (just install bazzaz, haven't tune after installed). As a result, a dyno tune should be best for my bike?
ora is offline
post #15 of 15 Old 01-08-15, 12:09
jdgun_13
jdgun_13's Avatar
The Bazazz unit has a preloaded slip-on map in it, under map 1 if not mistaken. you can opt to run map 2 which is the zero map (no fueling changes). there is a plug which is designed to be used with the map switch, BUT it has a connector plugged into it and should be map 1 slip-on, removing it, defaults the bazazz to map 2 zero map. it is in the instructions.
jdgun_13 is offline
Tags
daytona 675r , exhaust , exup , tuneecu
