Can't unscrew the fuel line bolts - Triumph675.Net Forums
post #1 of 7 Old 02-03-20, 22:38 Thread Starter
iadminko
iadminko's Avatar
Hi all,
Ladies and gents, I'm experiencing pretty tough situation - i need to remove the fuel line from my Street Triple but for some reason those bolts are sitting insanely tight.
After several tries the screwdriver sitting place is almost destroyed. WD-40 doesn't help.
Now i really don't know what option should i try? Can i use impact screwdriver (wouldn't it damage the throttle body)? Or just make a thin cut on the head and try with flat screwdriver?
Help!
iadminko is offline
post #2 of 7 Old 02-04-20, 07:44
TTRIgnitionSystems
Site Sponsor
TTRIgnitionSystems's Avatar
Soak it with a good penetrating oil (WD40 doesn't count), let it sit overnight. Use an impact driver, but just rap it firmly - you aren't trying to swing it over hand like Thor's Own Hammer!
If this doesn't work, you can either slot the head or drill it off; once the rail is out of the way, there's plenty of room to grab it with a small Vice-Grip.
TTRIgnitionSystems is offline
post #3 of 7 Old 02-10-20, 20:31
Gzblack2
Gzblack2's Avatar
A little late but howd it go?
If your still at it,you can try to heat it with a soldering iron....
Worth a shot.
Gzblack2 is offline
post #4 of 7 Old 02-11-20, 07:33
Gosling 1
Those screws in the picture look like they have a little punch mark (dot) on the heads, If so, those are JIS screws not Phillips. I have several sizes of Vessel Impacta JIS screw drivers that work great on these types of fasteners. They look like regular drivers but have metal end caps and work as impact drivers too. Amazon and ebay sell them, I have the #2 and #3 versions.
https://www.amazon.com/Vessel-Megado...99631147&psc=1
Gosling 1 is offline
post #5 of 7 Old 02-11-20, 08:27
Renboy
Renboy's Avatar
Screwdriver socket with a ratchet.
Renboy is offline
post #6 of 7 Old 02-12-20, 19:23
Gzblack2
Gzblack2's Avatar
Jis was my first thought, maybe its my phone but I dont see the dimples.
Gzblack2 is offline
post #7 of 7 Old 02-13-20, 06:39
Stephen Pilsworth
Worst case as it's a long bolt is drill the head off, and extract what's left.
Hated removing mine, but made sure I put copper slip on them when they go back in.
Stephen Pilsworth is offline
