Threadstarter
So the bike started up today first time.
I’m of the impression that this was because of leaving the fuel to dry out of the spark plugs and fuel rail as well as completely draining the tank and cleaning the fuel pump filter; I guess fuel quality was the issue here.
New problem, it’s sounds like it’s running on 2 cylinders. Plugged in TuneECU and sure enough it comes up with error code P0353 ignition coil circuit fault cylinder 3.
Can I please get a heads up on which one is cylinder 3? I believe as you’re sat on the bike, it’s the right hand cylinder?
I’ll take it off tomorrow and check the spark from it. So I can get ahead of the game, potential causes of this are the ignition coil, the spark plug, are there any other places to look?
