What gas tanks will fit - Triumph675.Net Forums
post #1 of 3 Old 11-09-19, 22:21 Thread Starter
subaruzi
subaruzi's Avatar
My 2009 Daytona?
I believe 06-12 Daytona will fit.
Same years in Street Triple?
Sent from my moto x4 using Tapatalk
subaruzi is offline
post #2 of 3 Old 11-10-19, 11:04
Renboy
Renboy's Avatar
Any tank from either Daytona or ST3 between those years will fit. However, the 06-08 tanks have different mounting points for the gas cap than the 09-12's do. The easiest solution is a keyless cap appropriate for the year of the tank you're buying.
Renboy is offline
post #3 of 3 Old 11-11-19, 18:54
beau
beau's Avatar
I was able to get a second gen OEM cap on my 2007 675 with slight modification. Like Renboy said, they changed the mounting configuration so you’ll end up with one short bolt that has no where to screw in. I ended up putting a small dab of glue on the underside of the bolt and just sticking it in the hole. Kinda jank but it worked and the cap isn’t going anywhere.
beau is offline
