RPHA-10 Wind Noise??? - Page 2 - Triumph675.Net Forums
post #11 of 17 Old 01-17-17, 08:45
Neanderthal
Neanderthal's Avatar
I use a Sena, can hear it fine with ear plugs (29db rated). Give it a few tries, and sometimes it takes a few different pair to find some that are comfortable. Once you do, I'm betting you'll never go without.
Neanderthal is offline
The Following User Says Thank You to Neanderthal For This Useful Post:
ramnakhle (01-17-17)
post #12 of 17 Old 01-17-17, 09:03 Thread Starter
ramnakhle
ramnakhle's Avatar
Will let you know how it goes
ramnakhle is offline
post #13 of 17 Old 01-19-17, 18:58
Bmore
Bmore's Avatar
Originally Posted by ramnakhle View Post
I have a Scala Q3 installed and like to hear some low volume music in the background. Also I have to be able to receive calls at all times. Can you hear the comms ok with earplugs?
Thank you all :)
i can't say for sure because i use a Sena, but i know from installing many Cardo Scala Riders that the exact position of the speaker in the helmet makes a difference in how much you'll hear
like the speakers should be lined up to your ear as perfectly as possible. that might seem unnecessary but heads are different from eachother
how to mount your fairings while high (very slowly with errors)https://youtu.be/OQbHxDPLkPM
Bmore is offline
The Following User Says Thank You to Bmore For This Useful Post:
ramnakhle (01-20-17)
post #14 of 17 Old 01-20-17, 01:31 Thread Starter
ramnakhle
ramnakhle's Avatar
Tried the earplugs.
Heaven.
Thanks all
I have installed the Q3 myself and the speakers are pressed right against my ears.
With the earplugs it is even better than without. The volume is just fine, and the sound is deeper, since all the noise is blocked by the earplugs, and it feels like a concert hall in there.
Just perfect.
And you hear your bike just fine.
Just have to be a bit more careful in traffic that's all.
I never thought I'd like using earplugs.
I am enlightened
Thanks guys.
post #15 of 17 Old 01-20-17, 22:45
Shamrock
Mean Green Mod
Shamrock's Avatar
And saves your hearing. :)
Shamrock is offline
The Following User Says Thank You to Shamrock For This Useful Post:
ramnakhle (01-21-17)
post #16 of 17 Old 06-07-17, 00:01
SV650sWanted
OP, check that the gasket is sealed towards the lower portion of the visor where the lock mechanism is. I just noticed a few days ago that my HJC RPHA 10 has this issue, HJC is sending me gasket material to hopefully fix the issue.
SV650sWanted is offline
post #17 of 17 Old 06-07-17, 00:22 Thread Starter
ramnakhle
ramnakhle's Avatar
Hey thanks for the reply.
The culprit turned out to be a gap in the passing where my communicator is inserted. Fixed that.
But still. Earplugs FTW.
The Following User Says Thank You to ramnakhle For This Useful Post:
Shamrock (06-07-17)
