Annitori RL quickshifter instructions - Triumph675.Net Forums
post #1 of 10 Old 02-28-20, 16:03 Thread Starter
bluedaytona02
bluedaytona02's Avatar
Does anyone have the instructions for the old Annitori RL quickshifter unit with the round control module?
I want to check/adjust sensitivity.
The Annitori site only has the Pro unit details.
I've also earthed it to the main earth rather than the battery. I had issues which presented like a failing QS sensor, however the CPS died shortly after pulling the QS off, so I'm reinstalling it.
TIA
Sent from my SM-G960F using Tapatalk
Current: '06 Daytona 675 ('08 BEARS winning bike - Chris Panayi) White with Pitty's Custom Vinyls TTC decals STM Slipper Clutch Braking wave rotors with folding/adjustable levers GB engine covers Valter Moto Rearsets Race kit detent wheel & idle adjuster 1050 throttle tube Captive Wheel Spacers MotoGems bling Vortex clip-ons, Stomp grip 520 conversion Puig screen Madaz slip-on Intake flapper & Ex-up removed Swing-arm pivot mod. Thinner head gasket Custom tune
bluedaytona02 is offline
post #2 of 10 Old 02-28-20, 18:40
TTRIgnitionSystems
Site Sponsor
TTRIgnitionSystems's Avatar
I can't comment on setting sensitivity, but there should be no issue grounding to the main ground bus. The instruction to ground it to the battery is more likely for your own convenience, so you don't need to go hunting.
TTRIgnitionSystems is offline
post #3 of 10 Old 02-28-20, 21:14 Thread Starter
bluedaytona02
I was trying to eliminate a poor ground as a potential issue.
The bike was cutting out violently at WOT. It was suggested that the QS sensor was faulty. It was worse however the more fuel I added (But not sluggish like a fuel issue). So I removed the SQ and replaced the fuel pump internals. Next race meet the CPS failed, so I put the violent cut-out down to that.
I've now replaced the CPS and reinstalled the QS but am yet to test.
post #4 of 10 Old 02-28-20, 21:32
TTRIgnitionSystems
Site Sponsor
Harsh shifting sounds more like the cut time was way too long.
post #5 of 10 Old 02-28-20, 23:18 Thread Starter
bluedaytona02
The engine would cut out like the QS switch was being activated, however my foot was not near the shifter and the sensitivity was on the lowest setting. It wasn't just occasionally either.
post #6 of 10 Old 02-28-20, 23:58
TTRIgnitionSystems
Site Sponsor
Yup - agreed & conceded. Either a loose / broken QS switch with contacts flapping about inside, or a bad CPS breaking sync in the ECU.
post #7 of 10 Old 02-29-20, 00:09 Thread Starter
bluedaytona02
I built another bike over the off season, so the QS is actually on that bike now. I guess it should then easily show if it's working properly or not.
post #8 of 10 Old 02-29-20, 00:24
TTRIgnitionSystems
Site Sponsor
If the symptoms persist on the new bike, unplug the sensor. If the problems go away, it's the switch; if they remain, it's the controller (unlikely, but possible). Assuming IT doesn't have a bad CPS!
So ... Do you need a replacement QS for the original bike? Such a deal ...
post #9 of 10 Old 02-29-20, 00:37 Thread Starter
bluedaytona02
Both bikes are gen 1 so need the stand alone units.
At this stage the "old" bike is being used as a wet bike, however the local track is being resurfaced (what a debacle) so I've not been able to test the new bike before it's first outing next week.
And as usual, life throws a few curve balls, and I'll likely need to sell the "wet" bike in the near future.
This QS unit comes with a blanking plug to allow you to unplug the sensor and still leave the coil loom in place. If symptoms persist, I'll just unplug it.
I'm not really in the market for another... and the AUD is pathetic when converted.
post #10 of 10 Old 02-29-20, 01:43
TTRIgnitionSystems
Site Sponsor
*nods* US$250 (sensor & controller) => AU$385, but not such a deal if you wind up selling the bike.
