Extreme Components GP Clip Ons + Bar Length - Triumph675.Net Forums
post #1 of 4 Old 02-27-20, 04:41 Thread Starter
Tim Hunt
Im still trying to get used to my new 2014 675r race bike i picked up recently. Ive had 2 track days on it since I got it and I still feel like I am not that comfortable on it.
It doesn't have anywhere near as much front end feel as my old stock 04 GSXR 600 (which is surprising) and it also still seems to hook into corners very sharply.
I've had it set up professionally after the first track day and also got the front serviced and re-valved with the race tech gold valves. It also came with a Matris steering damper which is installed and set to the maximum setting (any less and it feels insanely light). Even after getting it looked at, it still feels light in the front and difficult to control.
The clip-ons that are on it are the extreme performance GP clip ons. I noticed that the angle they sit is a bit more aggressive than I had on the GSXR and the bar length is quite a bit different. About 5cm longer per bar with these clip ons.
My questions are
1. Anu suggestions on how I can get more front end feel back to the bike?
2. How much does the angle of the bars affect this?
3. How much does the length of the bars affect it?
If anyone has had experience with the extreme components parts, it would be good to hear
Tim Hunt is offline
post #2 of 4 Old 02-27-20, 05:31
bluedaytona02
bluedaytona02's Avatar
On my gen 1 bike, I have the forks pushed through (8mm gold showing from memory) and have added 3mm shim above the stock rear shock shim. I also run 180/60 rear tyre.
I had a friend suggest the bike was too nose down, so I set forks back to stock position (4mm gold showing??) and removed the extra shock shim. After that, the bike felt vague and pushed wide in corners and I could feel it sliding the front.
Needless to say, I went back to the above set up.
I also have my clip-ons dropped down with a 6mm gap between the top triple and the clipon bracket.
This on a gen 1 bike, so geometry is different, but that was my experience.
Sent from my SM-G960F using Tapatalk
Current: '06 Daytona 675 ('08 BEARS winning bike - Chris Panayi) White with Pitty's Custom Vinyls TTC decals STM Slipper Clutch Braking wave rotors with folding/adjustable levers GB engine covers Valter Moto Rearsets Race kit detent wheel & idle adjuster 1050 throttle tube Captive Wheel Spacers MotoGems bling Vortex clip-ons, Stomp grip 520 conversion Puig screen Madaz slip-on Intake flapper & Ex-up removed Swing-arm pivot mod. Thinner head gasket Custom tune
bluedaytona02 is online now
post #3 of 4 Old 02-27-20, 06:30 Thread Starter
Tim Hunt
Thanks mate. Are you using a stock or aftermarket triple clamp? I am running the attack triple clamp but i need to get that looked at too as it wasnt lining up perfectly when it was put back together so not sure if the bottom clamp is bent and that is affecting it.
But the bars do seem very long so thats why I was wondering if the extra leverage from longer bars was throwing it off too.
I havent had any issues with it running wide at this point, in fact quite the opposite. A few times I have turned in more than expected at hit the ripple strip.
Tim Hunt is offline
post #4 of 4 Old 02-27-20, 13:24
bluedaytona02
Stock triples.
Wider bars should give more leverage, like dirt bike bars would.
