2013 STR Translogic QS Problems. Misfiring? - Triumph675.Net Forums
post #1 of 2 Old 01-12-20, 01:45 Thread Starter
Devin17C
Devin17C's Avatar
I purchased a Translogic Quickshifter off of Facebook and installed it in my biker over Christmas. The installation went good expect that Triumph had a right and left handed thread on the shift rod while the quickshifter needed 2 right hand threaded ones.
When starting it up and going for a quick ride, it sounds deeper then normal and doesn't have any power when going for a quick ride. It seems likes it's misfiring but everything is plugged in correctly and is securely fastened. Should I change the spark plugs and how would I check the coil packs to make sure they are good?
Any recommendations would be good at this point, I thought I installed everything correctly to Translogic's manual but I might have missed something. If I can't narrow it down or figure it out with your guy's help, I might take it to the dealer or just remove the quickshifter.
Devin17C is offline
post #2 of 2 Old 01-13-20, 08:59
DonTZ125
DonTZ125's Avatar
Unplug the sensor; see if that makes a difference.
DonTZ125 is offline
