New turn signals flashes only once - Triumph675.Net Forums
post #1 of 6 Old 01-05-20, 21:40 Thread Starter
whatever
I replaced my front turn signals with the afcsignals turn signals and everything is connected correctly, but whenever I try to use it, it'll flash once and then my turn signals stop working for about 10 - 20 seconds. I can't use the other signal within that 10-20 seconds. Afterwards I can try using it again, but same issue. I swapped back to stock and it works perfectly fine. I used the resistors that were provided with the turn signals. Can't figure out what the issue is here.
whatever is offline
post #2 of 6 Old 01-06-20, 00:48
Stephen Pilsworth
Have you tried changing the OEM relay. Left side of the bike just inside the fairing behind the radiator down the bottom.
Could be it overloads and gets stuck.
Stephen Pilsworth is offline
post #3 of 6 Old 01-06-20, 01:26 Thread Starter
whatever
Should I replace it with the oem one (T2506000) or led one (A9830046)?
whatever is offline
post #4 of 6 Old 01-06-20, 10:17
Stephen Pilsworth
Would go on eBay and buy an led one from their. Had issues with the OEM one not working.
post #5 of 6 Old 01-14-20, 11:57
Pathfinder
Pathfinder's Avatar
Check this plug n play relay, not cutting wires! https://www.customled.com/products/e...SABEgK2TvD_BwE
If you can't stand behind our troops, please, stand in front of them!
Pathfinder is offline
post #6 of 6 Old 01-19-20, 20:54
DayT675
It's going to sound weird but take out the resistors and see if it hyper flashes
DayT675 is offline
